2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com 197 - Whiteline Performance - 1
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Ford Bronco Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com > 2015+ Ford Mustang Forum > Shelby GT350 Mustang
Shelby GT350 Mustang Discussions of the 2015+ Shelby GT350 and GT350R Mustang
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 08-30-2017, 12:31 AM   #1
Tank
9/11 - Never Forget
Tank's Avatar
Drives: G0853; 2015 Tacoma
Thanked: 817 Times in 532 Posts
iTrader Score: 0 reviews
GT350 BASICS, WHAT'S NORMAL, DON'Ts, DELIVERY/ROUTINE CHECKS & OTHER STUFF
This thread has been developed for the Mustang6g community on the 2015 and up GT350 manufactured by Ford at the Flat Rock Assembly Line, Flat Rock, MI. You are encouraged to take a look and participate with your first-hand experiences.
Ground rules (feel free to suggest others):
  • Issues generating debates will be added when 5 or more members report experiencing the issue.
  • Use & follow the links to get more information for any issues.
  • Owners Manual and Shelby Supplemental Manual- read thoroughly and as needed during ownership
High priority is defined as something to do to avoid a catastrophic failure. Suggested check interval = weekly.
Moderate priority is defined as everything else. Suggested check interval = at owner's comfort level.
Miscellaneous Info
  • Ford Performance- 1 (800) 367-3788‬
  • It’s got a 16 gallon gas tank.
At Delivery, check for the following:
  • Front and rear suspension spring spacers are removed. If they are not and you find them still installed when you get home, you might need to have the magneride reset if you’re getting error codes. See dealer for fix, search 'magneride' for more info.
  • Rear bumper gap- measure to get baseline at delivery then again when you notice it growing (if applicable)
  • Panel fitment in general
  • Look for any signs of damage due to improper transport- misaligned/miscolored panels, front undercarriage damage. If possible, can you be there when the truck arrives? All GT350s are supposed to be loaded on the bottom deck , facing backwards and no deeper than the third position from the rear. See shipping decal at http://www.mustang6g.com/forums/show...0&postcount=26
  • Bird droppings on your stripes can cause permanent damage. Ensure it can be cleaned off with no visible defects.
  • Then, bed them big-ass Brembos ASAP
What's Considered Normal (Thanks to @montreal ponies for this catagory)
  • Piston slap, also known as "flapping" to a particular Canadian
  • Brakes squealing
  • Tramlining
  • Brake dust, lotsa brake dust
  • Expect to have to fill 'er up everytime you drive the car
  • According to the March 2017 Shelby Supplement pg. 48, oil consumption of "approximately 1 quart per 500 miles" while "driving high performance vehicles in such a way that might lead to higher oil consumption (this includes extended time at high engine speeds, high loads, engine braking, hard cornering maneuvers and track use."
Don't
  • Allow your GT350 to be towed with a slingbelt or wheel lift equipment
  • Lift driver's side wiper quickly
  • Use pneumatic wrench to set the torque on your lug nuts
  • Go to redline until engine oil temp reaches 190 F degrees. On a cold day, this might not happen or could take a while.
  • Let bird excrement stay on your stripes
  • Take to an automatic car wash - parts may be blown off the car.
High Priority Checks:
  • Engine oil level. See post #27 in this thread for how to do this.
  • Brake master cylinder to clutch master cylinder reservoir line fitment (less frequently than weekly if modified with clamp or similar)
Moderate Priority Checks:
Drive train and related
  • Torque on oil filter - first gen, spin on filters.
  • Engine to Oil Cooler lines for leaks
  • "C" Ring on Oil Filter Adapter- property seated (at least once after delivery)
  • Lug nut torque
  • If you've installed them, check and empty catch cans as needed
  • Check fuse box for loose fuses and loose battery cables
  • Bottom edge of radiator for weeping coolant. Members report coolant can accumulate on the topside of the under belly pan so detecting this might not be so easy unless you drop the pan.
Chassis, body...
  • Side vent trim piece pulling away from body
  • Rear bumper gap- this may continue to expand.
  • Splitter installed correctly- anytime someone other than owner removes and reinstalls it.
Where To Start When Things Go Wrong
  • Hood Flutter - check under hood, esp. drivers side, bumpers for possible adjusting.
__________________
Tank is offline   Reply With Quote
Old 08-30-2017, 12:39 AM   #2
Tomster
Will fly for beer
Tomster's Avatar
Drives: 2 - 17 GT350 R's
Thanked: 1,751 Times in 1,004 Posts
Sounds like a sticky to me
Tomster is offline   Reply With Quote
Users thanking this:
Old 08-30-2017, 12:47 AM   #3
KiLLeR2001
Drives: '89 240SX, '17 GT350
Thanked: 246 Times in 131 Posts
If you have catch cans installed, empty out passenger side catch can every X amount of miles depending on your vehicle.
__________________
http://tehl33tsite.com/sigs/gt350-3d.png
KiLLeR2001 is offline   Reply With Quote
Old 08-30-2017, 01:08 AM   #4
Feathermerchant
Drives: None yet
Thanked: 1 Time in 1 Post
Check line from brake master cylinder reservoir to clutch master cylinder. The connection at brake master cylinder reservoir can be loose.
Feathermerchant is offline   Reply With Quote
Old 08-30-2017, 02:40 AM   #5
icormba
icormba's Avatar
Drives: Jeep SRT8 / GT350R / FocusRS
Thanked: 664 Times in 363 Posts
Low priority...
Check fuse box for loose fuses and loose battery cables maybe once every 6 months.
__________________
Thanks, Chris M
icormba is offline   Reply With Quote
Old 08-30-2017, 08:08 AM   #6
Tank
9/11 - Never Forget
Tank's Avatar
Quote:
Originally Posted by icormba View Post
Low priority...
Hey Chris,
When it comes to the GT350, there is no 'low priority'
That's a new one to me. Do you know of any threads discussing this issue?
Thanks for the suggestion
__________________
Old 08-30-2017, 06:53 PM   #7
TDC
TDC's Avatar
Drives: GT350
Thanked: 771 Times in 502 Posts
- Radiator for light weeping of fluid along the bottom edges
__________________
2016 GT350. White w/Blue OTT stripes. Tech
TDC is offline   Reply With Quote
Old 08-30-2017, 10:30 PM   #8
chitlins37
chitlins37's Avatar
Drives: 17' Magnetic GT350R / 70' Buick Skylark
Thanked: 160 Times in 118 Posts
Check for front and rear spacers upon delivery of the car.
chitlins37 is offline   Reply With Quote
Old 08-30-2017, 10:31 PM   #9
chitlins37
chitlins37's Avatar
Oh and NEVER pull the driver side wiper arm up quickly :/
Old 08-30-2017, 10:53 PM   #10
VooDoo387R
Drives: GT350R
Thanked: 74 Times in 44 Posts
Quote:
I hear that brother...lol
__________________
2017 Race Red GT350R with Electronics Package and Car Cover, HR387 - XPEL Ultimate Full Wrap; 40% Tint; Opti-Coat Pro Plus Ceramic on everything; JMS PEDALMax; K&N Air Filter; FP Oil Catch Cans; JLT Master Cylinder Cover; Redline Color Matched Tuning Bolt-in QuickLIFT Hood Struts; JLT Color Matched Strut Covers; JLT Color Matched Coil Covers; JLT Rock Blocker; LED light kit. Upcoming Mods: CorteX / DSC Sport V2 Magnaride Controller Module; Carbon Fiber Driveshaft; Alcantara Arm Rest, Shift and Brake Boot, Kick Panel's
VooDoo387R is offline   Reply With Quote
Old 08-30-2017, 11:56 PM   #11
sher-bant
sher-bant's Avatar
Drives: 2017 Shelby GT350
Thanked: 29 Times in 23 Posts
MY CAR HAS A SCAR FROM ME PULLING UP THE WIPER.
sher-bant is offline   Reply With Quote
Old 08-31-2017, 08:22 AM   #12
Tank
9/11 - Never Forget
Tank's Avatar
Quote:
Hey @TDC ,
That's a new one to me, has this been discussed anywhere?
__________________
Old 08-31-2017, 10:51 AM   #13
Shift
Drives: a Ford
Thanked: 864 Times in 583 Posts
Im glad someone posted about this, as I was able to use this info before I received my car last year.
Also having a regular issue where I have to fill up every day I drive the car
Shift is offline   Reply With Quote
Old 08-31-2017, 11:43 AM   #14
montreal ponies
montreal ponies's Avatar
Drives: Trans temp limited '16 Magnetic GT350
Thanked: 962 Times in 661 Posts
I'd be cool to add a " normal caractheristic of the car " thread
Piston flapping
Brakes squealing
Tramlining
Brake dust
are the ones i'm tinking right now.
Nice initiative Jim, thx.
__________________
2016 Shelby GT350
2016 Edge Sport
2017 Transit connect
and many other Ford's over the years.
montreal ponies is offline   Reply With Quote
Old 08-31-2017, 11:53 AM   #15
nastang87xx
nastang87xx's Avatar
Drives: 2016 GT350 Track Pack
Thanked: 1,475 Times in 916 Posts
Bed in your brakes with hard braking immediately.
Throw out the "1000 miles' of testicle fondling the throttle bullshit and just give it the beans.
__________________
Current: 2016 GT350||900A||60T||PQ853||
Gone and never forget: 2011 GT Premium, Black, 400A, 55D, BB
GT350 break in procedure
nastang87xx is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Price Check on OEM GT350 Wheels Schmitty19 Interior and Exterior Modifications 5 08-11-2017 08:34 PM
Things to check before picking up your car Manders Mustang United Kingdom 54 04-28-2017 02:21 AM
Check out our 2016 Shelby GT350 video 142KMPH Shelby GT350 Mustang 8 05-24-2016 11:05 PM
What are some things you DON'T like about the GT350? Fox9350 Shelby GT350 Mustang 157 03-13-2015 06:06 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
