EF300
- Aug 24, 2015
- The Swamp, Central FL
- 2017 GT350, 2020 GT500 CFTP
I am very sad to write this message but here is the current story.
About 6 months ago I had the Evap core on my ac unit go out. Ford warrantied the Evap core but also found and issue with the AC compressor not kicking on. At that time they changed the AC compressor as well. All seemed fine until I noticed a strange sound under the hood. Long story short, the AC compressor had come loose from the engine and thrown the AC stretch belt. The tech said something may be wrong with the compressor clutch causing the belt to come off so they need to remove and warranty out the AC compressor again.
Later that day I got a call for the service manager stating that during removal of the compressor a bolt sheared off in the block. To remove the bolt they had to drill it out of the block. They went ahead with the work and the next day said everything went well, the bolt was out and the AC compressor was fixed.
Well the other day I heard a "clunk" under the hood so I dropped the car off for service at A DIFFERENT dealership. Today they called to tell me that there is a sheared off bolt in the block in the AC compressor post and the other two bolts posts in the block were heli coiled. They are saying its basically impossible to fix correctly and a new block is needed.
Looking through my service history the dealership that originally "fixed" the AC compressor made no mention of a broken bolt in the block, drilling a bolt out or putting heli coil in the block posts. Luckily I have a text message from the service rep stating that 1 bolt was broken off in the block and they repaired it.
The car is being towed back to the original dealership that seemingly botched the repair for evaluation. Needless to say I am almost certain that ford will punt any repair / engine replacement costs back on to the dealership rather than warranty it out.
I am going to give the dealership a chance to do the right thing.
Attached are pics of the botched repair showing a sheared bolt and 2 heli coils in the block.
TY
Sheared bolt
Heli coil
Helicoil
TY
Sheared bolt
Heli coil
Helicoil
