Funny, the slappy things aren’t mentioned as a reason not to take it through a commercial carwash in the Supplemental....
CLEANING THE EXTERIOR
Washing Your Vehicle
Do not drive your vehicle through an automated, commercial car wash due to the vehicle’s low ground clearance and tire width. Wash your vehicle by hand, or by using a touchless commercial wash with no mechanical tracks on the floor. Do not use a power washer or high pressure wand. See the Owner’s Manual for information on cleaning products and vehicle care.
He would have to do a rinseless or waterless style wash most likely depending on where he is. I'd say from October/November through at least April you can't use a hose, they are clogged up with ice.Water freezing cold? Mix some hot water into your bucket. Wear a layer or two of disposable gloves. Rinse your car with the cold water, and wash it with your warm soapy water. There's ways to wash your car, he just didn't want to go through the trouble. I've never had to deal with well water, but if you're using it for your household needs, it'll do fine for washing cars. And if you're really worried about water spots and you cant dry it off fast enough, but a few gallons of distilled water and do your final rinse with that.
Hey Frank, this is not my though. I saw this on FB. Decide to post here.Find a GOOD body shop. They should be able to do your fender without blending.
I had a Corvette rear-ended and had PPF on the rear quarters. Didn't want them to peel the PPF so they just painted the
rear fascia without blending. Came out perfect.
With today's tech, blending shouldn't be necessary.
We don’t typically ever blend other panels when painting a bumper unless it is a horrible color. Most every other panel will get blended when repaired. Unless it is straight black then you can typically panel paint those, but black still will have some brown mixed in and that can cause a problem.Find a GOOD body shop. They should be able to do your fender without blending.
And the inside of their fenders ...Anyone who use's those car washes needs their heads examined
