ChipG
- Jan 27, 2021
- Nashville TN
- Chip
- '20 GT350/'95 F250/'65 Fastback/'96 Cobra Project
Hi all,
In preparation for the arrival of my wheels in a few weeks, I needed to install longer studs in my front hubs. I decided to go with R-length front studs from OPMustang, and I picked up mid-length rear studs to match. I had a weekend with no kids, no commitments, and good weather, so it was time to wrench!
Here's a comparison of the new studs and nuts (bottom) next to the OEM hardware.
This should give me plenty of room for a 35mm spacer and be stronger for track use to boot.
First get the car in the air and supported.
And now to tackle the front hub. Remove the wheel, move the caliper (thanks Caliperfexion!) and remove the rotor. I've seen some say they removed the caliper entirely but I was able to get everything done this way.
Now for the hub bolts. For the front two, I used a 1/2" drive ratchet with a deep 18mm socket. All the hub bolts front and rear took a pretty good pull to break loose but then were relatively easy to remove once broken free.
For the rear two bolts, I used an extra long box-end ratcheting wrench with swiveling heads, which worked well.
Take the bottom bolt off first and LEAVE THE TOP REAR BOLT FOR LAST! I'll show you why.
On the top rear hub bolt, using a box end wrench will eventually get you stuck against the lower knuckle mounting nut. You won't be able to get the wrench off, you won't be able to back the bolt all the way out, and you can't reverse unless your wrench has a direction reverse switch (mine doesn't). The only way out is for all three other bolts to be loose/removed. I got good and stuck but was fortunately able to get the other bolts off so I could pull the hub forward. Here's the issue:
Learn from me - my dumb ass forgot by the time I went to the passenger side and almost screwed myself again!
So, front hub removed, I found that there was a good bit of rust on my hubs, I assume from sitting for 1+ years before I bought the car since I've only had the car for 3.5 months and 6k miles.
So I pressed out the old studs and cleaned things up a bit with a wire brush and some brake cleaner.
Time to press in the new studs! The first four are pretty straightforward:
For the last one, the four studs in wouldn't fit between the rails on my press, so I had to get creative to make space to press in the last:
Time to put it back together now. Remount the hub. I started with the top right for clearance and I used a little blue loctite and reused the bolts. Since I couldn't get a torque wrench in there, I torqued them all to "gudentite." I actually used a torque wrench on another bolt set to 100 ft-lbs. and tried to "feel" how hard a pull that was so I endeavored to get that strong a pull on each hub bolt.
Replace the rotor, slide the caliper back in, re-attach the Caliperfexion nuts with a little ARP assembly lube and torque to 80 ft-lbs.
New remount the wheel. For comparison, the OEM lug nuts:
New studs and nuts.
The new nuts only need to be torqued to 100 ft-lbs. due to the coating.
Whew! Time for a beer and a break. If you thought that was fun, wait for the rear - now THAT'S a good time.
While resting, I got a visitor who wanted to check out my tools...
I guess he wanted to see what he wanted to be when he grows up!
Rear hubs (and bigger screw-up) in next post.
New studs and nuts.
