10R80 Owners - ULTIMATE M6G 10R80 Facts + Resolutions to harsh or no shift conditions
This will be the “official” 10R80 thread. It contains Facts and links to other important 10R80 posts on this site.
10R80 “newbies” - if you just bought a new or used S550 w/10R80, scroll down to all of the “facts” and review the attached PDFs. This thread contains a TON of info for you newbies and helps you to understand the characteristics, inner workings of the 10R80, how to use the Trans Modes vs. Drive Modes, and paddle shifting info.
It will also serve as a repository for those who have had issues with their 10R80, were able to get resolution and so those owners can post what they or their Service Center did for resolution. Hopefully it will also help others possibly get resolution who may have inexperienced Service Centers.
__________________________
EDIT May 2020:
Attached PDFs; users will find the information pertaining to the 10R80 dipstick variations and trans fluid documents.
The known S550 10R80 issues (does NOT affect all S550’s equipped with 10R80’s):
1) Harsh, clunky or jerky downshifts - usually most present during the 4-3, 3-2 or 2-1 downshift in Normal trans mode and can be more harsh when in Sport trans mode.
2) Harsh, clunky or jerky upshifts - usually most present during the 3-4, 5-6 upshift in Normal trans mode and can be more harsh when in Sport trans mode.
3) Stuttering of shift points when coming to a stop or accelerating. It feels like the trans is unable to determine which gear to go into as the RPMs are increasing.
4) Lack of initial engagement into from Park into Reverse if exterior temps are below 50*.
5) Lack of engagement from Park into Reverse when car is totally in normal temp range (190*-210*), regardless of exterior temps.
6) Extremely harsh engagement from Park into Reverse OR from Reverse to Drive (1st gear). Exterior temps do not matter. The engagement can be so harsh that it feels as if the car has been hit by another vehicle or like the driveline will rip the rear from the car.
7) Erratic shifts - seems like the trans is hunting or prematurely auto shifts gears when it should not be doing so.
8) Trans seems to remain in a higher gear when slowing down as vehicle MPH is decreasing when trans should actually be going into an obvious lower gear.
FACT 1 (Ford Trans Fluid notes):
Per Ford:
Use only Motorcraft MERCON® ULV Automatic Transmission Fluid XT-12-QULV (WSS-M2C949-A) or equivalent when servicing a 10R80 automatic transmission.
FACT 2 (10R80 SSM/TSB's):
The early 2018 S550’s w/10R80’s did have some operational issues with software and hardware. These issues (some minor and some major) were addressed by Ford through TSB’s or SSM’s. The link below contains ALL such info and docs as of today’s date. That thread gets updated when there is any new release of such info.
https://www.mustang6g.com/forums/th...ost-recent-tsb’s-in-here.102918/#post-2336328
FACT 3 (Adaptive Learning Info):
The 10R80 is an adaptive learning transmission. The below thread contains the information about how to reset the adaptive learning of the 10R80 based on M6G Members and Ford’s recommendations (Post # 15 has the Ford Shop Manual info - thanks goes to @DickR):
https://www.mustang6g.com/forums/threads/question-on-10-speed.105430/#post-2702026
Adaptive learning can also be reset via Forscan for those who use the tool (thanks goes to @Blown86GT):
Hopefully you are familiar with the software and have the correct adapter. If not, let me know and I can send you the Forscan software link and the laptop adapter I used to hook up to my car.
Click on the wrench button within FORscan. You will see several modules listed under the service procedures tab. Click on clear adaptive strategy for the PCM module. Then push the play button at the bottom of the FORscan GUI. Once complete, you should be set...
Shout out to @andrewtac for the Forscan info for valve body strategy access:
https://www.mustang6g.com/forums/threads/changing-valve-body-startegy-in-forscan.170382/
FACT 4 (LOW FLUID & DIPSTICK info):
M6G Members with 10R80’s have found that their 10R80 was low on fluid from the factory. If you suspect your shifting issues may be due to low fluid level, have your Ford Service Center check the fluid (or you can DIY at home with car safely jacked up or on a lift). Here’s 2 low trans fluid threads:
https://www.mustang6g.com/forums/threads/2018-10r80-low-on-transmission-fluid.132066/#post-2733064
https://www.mustang6g.com/forums/threads/a10-owners-check-your-oil-level.116410/
2 threads on checking 10R80 fluid levels:
https://www.mustang6g.com/forums/threads/10r80-fluid-check.137537/#post-2827033
This thread discusses the (2) very different 10R80 dipsticks - thanks to @leonrudi and @speedup for their findings!):
https://www.mustang6g.com/forums/threads/a10-fill-plug-impossible-to-remove-help-plz.141548/
The B&M 10R80 B&M dipstick for the F150 will NOT work with the S550 10R80:
https://www.mustang6g.com/forums/threads/2018-10r80-dipstick.136868/
FACT 5 (Powertrain Warranty):
The Ford Powertrain/Drivetrain Warranty is 5/60. The transmission is covered under this warranty even if the new car 3/36 is expired.
My 2018 was at the Ford Service Center in January 2020 for 10R80 shifting issues. Up until 2 weeks ago and since the car was purchased new, I didn’t have any shift issues up until 35k. The issues were resolved and here’s the complete Tech diagnosis and resolution. The trans no longer has any harshness, clunkiness or shift issues in any Trans Mode, Drive Mode or when shifting from Park to Reverse or from Reverse to Drive (1st gear). Even when slowing down and coming to a stop, the 10R80 shifts are flawless and it’s almost hard to tell the trans is even downshifting.
IMPORTANT NOTES:
1) Disconnecting the battery and/or resetting vehicle KAM will not update the trans software. It will not fix any issues IF the abnormal shifting is due to internal mechanical malfunctions (ie: valve body, torque converter, clutches, etc.)
2) If the 10R80 is “reflashed” with the most current software strategies by a Ford Service Center using IDS AND the abnormal shifting conditions remain AFTER a genuine trans reflash - the issue is NOT software related, it’s mechanical. Even with the trans being an adaptive learning trans, after an IDS software update and if the Tech has already performed the “relearn strategy”, when the Customer receives the car back - the trans should NOT have any harsh or abnormal shift conditions at all. If your 10R80 still has shift issues after a software reflash, it’s definitely a mechanical issue; print the above Tech notes and tell your Service Center they must do a similar diagnosis BEYOND just a test drive or software reflash.
For those NOT getting resolution from their Service Centers for ANY Warranty repair efforts, this thread contains all of the Ford 800# info to getting a Regional CSR to assist with your concerns:
https://www.mustang6g.com/forums/threads/the-ford-800-info-for-those-needing-it.111571/
For 10R80 Newbies, all you need to know:
The design and workings of a 10R80:
https://www.motor.com/magazine-summary/need-10-speeds/
SAE International Automotive Engineering article; go to page 10 about the 10R80:
https://www.mustang6g.com/forums/attachments/sae_16autd07-pdf.349718/
10R80 Internal Tech:
https://www.mustang6g.com/forums/threads/10r80-internal-technical-info.141611/
10R80 Trans Modes vs Drive Modes + Paddle Shift facts:
https://www.mustang6g.com/forums/threads/drive-modes-the-a10.141350/#post-2896682
EDIT May 2020:
10R80 Cooling upgrades:
For those seeking to improve 10R80 cooling, see this excellent tech thread:
https://trackmustangsonline.com/threads/10r80-automatic-trans-cooling-questions.14765/
See M6G Member @Flyhalf tech and upgrades for improving 10R80 cooling:
https://www.mustang6g.com/forums/threads/10r80-hesitation-at-230f.120806/
https://www.mustang6g.com/forums/threads/10r80-modest-cooling-upgrades-aftermarket-metal-pan.171215/
MISHIMOTO Trans Cooler threads:
Thanks to @thornclaw for his info about the positioning of the trans cooler:
https://www.mustang6g.com/forums/threads/mishimoto-trans-cooler-install.178601/
https://www.mustang6g.com/forums/th...himoto-auto-trans-cooler.175998/#post-3558973
EDIT 12/23/20:
10R80 alternative Trans Pans:
Looking for a 10R80 Deep pan? There’s currently one in the works as of Feb. 21, 2020:
https://www.mustang6g.com/forums/th...ep-pan-in-development-pml-your-covers.141605/
PML Deep Pan Link (Note: Deep pan design works on F150/SUV; may work on S550 Mustang but beware of ground clearance):
https://yourcovers.com/pml-ford-10r80-deep-transmission-pan.html
PML stock metal pan replacement:
https://yourcovers.com/pml-ford-10r80-stock-capacity-transmission-pan.html
@Firsttexan for providing the PML Aluminum 10R80 pan upgrade info (and testing for PML):
https://www.mustang6g.com/forums/th...ng-for-prototype-testers.172843/#post-3502723
PPE 10R80 deep metal pan discussion:
https://www.mustang6g.com/forums/th...sh-or-no-shift-conditions.135463/post-3104879
PPE 10R80 Aluminum Pan (stock depth replacement):
https://www.ppepower.com/shop/heavy-duty-cast-aluminum-transmission-pan-ford-10r80-trans.html
TMO.com 10R80 pan discussions:
https://trackmustangsonline.com/threads/aluminum-pan-for-10-speed-transmission.16778/
More PML aftermarket 10R80 trans pan discussion:
Tracking your 10R80?
This thread has great info provided by @sdiver68 and @Flyhalf:
https://www.mustang6g.com/forums/threads/10r80-on-the-curvy-road-race-track.109576/
EDIT June 2021 (10R80 internals info):
Great Gears Magazine article about the internals and shifting characteristics of the 10R80 is attached in PDF format. It's called "The More You Know About the 10R80, the Better Off You Are!".
EDIT August 2021 (10R80 gear ratios):
10R80 gear ratios from 2018-2021:
https://www.mustang6g.com/forums/th...1st-time-10r80-gear-ratios-are-listed.159312/
10R80 Drum clutch upgrades (thanks to @beefcake for this valuable information):
https://www.mustang6g.com/forums/th...ter-and-whats-available-for-the-10r80.164143/
EDIT Feb 2022:
10R80 shifter clip under trans tunnel breaks:
Thanks to @Nightmare5.0 for this new thread regarding the deterioration of the 10R80 shifter clip that will prevent the shifter from going into P or S:
https://www.mustang6g.com/forums/threads/10r80-broken-shifter-clip.171702/#post-3483628
EDIT March 2022:
Shout out to @19VelocityBlueGt for the fluid change/PPE pan install and @CORNYOTE for the Richardson cooling upgrade info.
https://www.mustang6g.com/forums/th...-darker-then-expected-at-14-000-miles.173245/
Shout out to @gpierce for providing the link to the YT video for 10R80 fluid change:
https://www.mustang6g.com/forums/threads/10r80-trans-fluid-change.173574/#post-3515403
EDIT June 2022:
Sonnax spring clip fix
Shout out goes to @TX-Ripper for his very beneficial “Sonnax spring clip” revelation regarding the weak factory spring clips that secure the solenoids on the 10R80 valve body. This is a MUST DO for anyone replacing their valve body:
https://www.mustang6g.com/forums/threads/beefing-up-a-10r80.175664/page-3#post-3573460
10R80 “Beefy Rebuild” w/tech and pics, courtesy of @schmeky:
EDIT SEPTEMBER 2022:
Shout out to @Jhonda and @Cory S for 10R80 trans swap info (ie: replacing an existing 10R80 with another 10R80 - no IDS or Forscan programming needed):
https://www.mustang6g.com/forums/threads/transmission-swap-year-to-different-year-update.179302/
EDIT DECEMBER 2023:
Shout out to @Frizbey87 for his tech DIY mod on how to “shift at the stick” by relocating the steering wheel paddle features to the trans shift lever:
https://www.mustang6g.com/forums/th...-manual-shift-buttons-on-shifter-knob.194705/
10R80 Tear Down/Rebuild video Courtesy, original content and compilation by Trans Tec:
Ford 10R80 SPECIFIC DIAGNOSTIC TROUBLE CODES (DTC's)
  • 10R80 Code (DTC) P1500 Vehicle Speed Sensor Intermittent
  • 10R80 Code (DTC) P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent Circuit-failure
  • 10R80 Code (DTC) P1502 Invalid or Missing Vehicle Speed Message or Brake Data
  • 10R80 Code (DTC) P1700 Transmission System Failure
  • 10R80 Code (DTC) P1701 Reverse Engagement Error
  • 10R80 Code (DTC) P1702 Transmission System Failure
  • 10R80 Code (DTC) P1703 Brake On/Off Switch Out of Self-Test Range
  • 10R80 Code (DTC) P1704 Transmission System Failure
  • 10R80 Code (DTC) P1705 Manual Lever Position Sensor Out of Self-Test Range
  • 10R80 Code (DTC) P1706 High Vehicle Speed Observed in Park
  • 10R80 Code (DTC) P1707 Transfer Case Neutral Indicator Hard Fault Present
  • 10R80 Code (DTC) P1709 Park or Neutral Position Switch Out of Self-Test Range
  • 10R80 Code (DTC) P1710 Transmission System Failure
  • 10R80 Code (DTC) P1711 Transmission Fluid Temperature Sensor Out of Self-Test Range
  • 10R80 Code (DTC) P1712 Trans Torque Reduction Request Signal Malfunction
  • 10R80 Code (DTC) P1713 TFT Sensor In Range Failure Low Value
  • 10R80 Code (DTC) P1714 SSA Inductive Signature Malfunction
  • 10R80 Code (DTC) P1715 SSB Inductive Signature Malfunction
  • 10R80 Code (DTC) P1716 SSC Inductive Signature Malfunction
  • 10R80 Code (DTC) P1717 SSD Inductive Signature Malfunction
  • 10R80 Code (DTC) P1718 TFT Sensor In Range Failure High
  • 10R80 Code (DTC) P1720 Vehicle Speed (Meter) Circuit Malfunction
  • 10R80 Code (DTC) P1721 Gear 1 Incorrect Ratio
  • 10R80 Code (DTC) P1722 Gear 2 Incorrect Ratio
  • 10R80 Code (DTC) P1723 Gear 3 incorrect Ratio
  • 10R80 Code (DTC) P1724 Gear 4 Incorrect Ratio
  • 10R80 Code (DTC) P1725 Insufficient Engine Speed Increase During Self Test
  • 10R80 Code (DTC) P1726 Insufficient Engine Speed Decrease During Self Test
  • 10R80 Code (DTC) P1727 Coast Clutch Solenoid Inductive Signature Malfunction
  • 10R80 Code (DTC) P1728 Transmission Slip Error
  • 10R80 Code (DTC) P1729 4x4 Low Switch Error
  • 10R80 Code (DTC) P1731 1-2 Shift Malfunction
  • 10R80 Code (DTC) P1732 2-3 Shift Malfunction
  • 10R80 Code (DTC) P1733 3-4 Shift Malfunction
  • 10R80 Code (DTC) P1740 Transmission System Failure
  • 10R80 Code (DTC) P1741 Torque Converter Clutch Control Error
  • 10R80 Code (DTC) P1742 Torque Converter Clutch Solenoid Faulty
  • 10R80 Code (DTC) P1743 Torque Converter Clutch Solenoid Faulty
  • 10R80 Code (DTC) P1744 Torque Converter Clutch System Stuck in Off Position
  • 10R80 Code (DTC) P1745 Transmission System Failure
  • 10R80 Code (DTC) P1746 Electronic Pressure Control Solenoid A - Open Circuit
  • 10R80 Code (DTC) P1747 Electronic Pressure Control Solenoid A- Short Circuit
  • 10R80 Code (DTC) P1748 EPC Malfunction
  • 10R80 Code (DTC) P1749 Electronic Pressure Control Solenoid Failed Low
  • 10R80 Code (DTC) P1751 Shift Solenoid A Performance
  • 10R80 Code (DTC) P1754 Coast Clutch Solenoid Circuit malfunction
  • 10R80 Code (DTC) P1756 Shift Solenoid B Performance
  • 10R80 Code (DTC) P1760 Transmission System Failure
  • 10R80 Code (DTC) P1761 Shift Solenoid C Performance
  • 10R80 Code (DTC) P1762 Overdrive Band Failed Off
  • 10R80 Code (DTC) P1766 Shift Solenoid D Performance
  • 10R80 Code (DTC) P1767 Torque Converter Clutch Circuit Malfunction
  • 10R80 Code (DTC) P1768 Performance / Normal / Winter Mode Input Malfunction
  • 10R80 Code (DTC) P1770 Clutch Solenoid Circuit Malfunction
  • 10R80 Code (DTC) P1779 Transmission Control Indicator Lamp Circuit Malfunction
  • 10R80 Code (DTC) P1780 Transmission Control Switch Circuit is Out of Self-Test Range
  • 10R80 Code (DTC) P1781 4x4 Low Switch is Out of Self-Test Range
  • 10R80 Code (DTC) P1782 P/ES Circuit Out Of Self Test Range
  • 10R80 Code (DTC) P1783 Transmission Over-Temperature Condition
  • 10R80 Code (DTC) P1784 Transmission Mechanical Failure - First And Reverse
  • 10R80 Code (DTC) P1785 Transmission Mechanical Failure - First And Second
  • 10R80 Code (DTC) P1786 3-2 Downshift Error
  • 10R80 Code (DTC) P1787 2-1 Downshift Error
  • 10R80 Code (DTC) P1788 Pressure Control Solenoid 'B' Open Circuit
  • 10R80 Code (DTC) P1789 Pressure Control Solenoid 'B' Short Circuit
  • 10R80 Code (DTC) P1795 Idle Switch Circuit Malfunction
  • 10R80 Code (DTC) P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
  • 10R80 Code (DTC) P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
  • 10R80 Code (DTC) P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
  • 10R80 Code (DTC) P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
  • 10R80 Code (DTC) P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
  • 10R80 Code (DTC) P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
  • 10R80 Code (DTC) P1819 Transmission Neutral Safety Switch Short Circuit To Ground
  • 10R80 Code (DTC) P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
  • 10R80 Code (DTC) P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
  • 10R80 Code (DTC) P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
  • 10R80 Code (DTC) P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
  • 10R80 Code (DTC) P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
  • 10R80 Code (DTC) P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
  • 10R80 Code (DTC) P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
  • 10R80 Code (DTC) P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
  • 10R80 Code (DTC) P1838 Transmission Transfer Case Shift Motor Circuit Failure
  • 10R80 Code (DTC) P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
  • 10R80 Code (DTC) P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
  • 10R80 Code (DTC) P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
  • 10R80 Code (DTC) P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
  • 10R80 Code (DTC) P1866 Transmission Transfer Case System Concern - Servicing Required
  • 10R80 Code (DTC) P1867 Transmission Transfer Case Contact Plate General Circuit Failure
  • 10R80 Code (DTC) P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
  • 10R80 Code (DTC) P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
  • 10R80 Code (DTC) P1881 Engine Coolant Level Switch Circuit Failure, GEM
  • 10R80 Code (DTC) P1882 Engine Coolant Level Switch Circuit Short to Ground
  • 10R80 Code (DTC) P1883 Engine Coolant Level Switch Circuit Failure, GEM
  • 10R80 Code (DTC) P1884 Engine Coolant Level Lamp Circuit Short to Ground
  • 10R80 Code (DTC) P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
  • 10R80 Code (DTC) P1900 Output Shaft Speed (OSS) Circuit Intermittent Malfunction
  • 10R80 Code (DTC) P1901 Turbine Shaft Speed (TSS) Circuit Intermittent Malfunction
  • 10R80 Code (DTC) P1902 Kickdown Solenoid Relay Control Circuit
  • 10R80 Code (DTC) P1903 Kickdown Solenoid Circuit Low Voltage
  • 10R80 Code (DTC) P1904 Kickdown Solenoid Circuit High Voltage
10R80 Owners: feel free to contribute anything that will help others.
View attachment 10R80 Fluid Level & Disptick info.pdf
View attachment MERCON_ULV_Automatic_Transmission_Fluid.pdf
View attachment Motorcraft Trans Fluid Chart Color.pdf
View attachment Motorcraft Trans Fluid Chart B&W.pdf
View attachment Gears Magazine | The More You Know About The 10R80... The Better Off You Are!(2).pdf
View attachment Raybestos 10R80 Clutch Clearances.pdf
You have 35000 miles on your A10?
Yes. I took delivery of my 2018 new in Feb 2018, as of last night it’s just ticked over 35.5k.
Zinc03svt
usa
stang
What was your build date? Mine was May 18.
I do not have most of those issues you listed. Car will down shift like a rev match occasionally in Drive, but I always blamed the tune for that. Stock tune drives out fine.
The VCL on the driver B-pillar shows a 01/18 date. I have my Special Order window sticker which probably has the complete actual build date info on it.
Thegipper
Orange County, CA
2020 Mustang GT PP1
My 2020 GT has the same clunky downshifts. I’m going to take it in this week regarding this and a rattle in the passenger C-pillar.
Bikeman315
Myrtle Beach, SC
Ira
Thank you CJ for this awesome post. Every 10R80 owner should bookmark it.
hlfbkd420
SW 'Merica
www.youtube.com
Bilbo Hicks
2019 GT w/ Roush P2 SC, 2015 KIA Sorento SXL
So that delayed/slow shift from 3rd to 4th at anything over 30% throttle isn't normal? My car shifts okay when just accelerating at a leisurely pace or WOT.. But anything over 30% and below WOT it is herky jerky.
Thegipper
Orange County, CA
2020 Mustang GT PP1
My biggest issue is the intermittent “clunk” when the transmission is slowing down and downshifting on its own mainly from 3-1 and sometimes from 4-3.
It happens on average every other day and statistically, it won’t happen if taken to the dealer. I don’t know if should take it in for this. I keep hearing that some of these left the factory short 1-2 quarts of transmission fluid or they have bad valve bodies. Mine is a 2020 so you’d think issues would get fixed, but this is Ford. Lol.
Dawgvet06
Atlanta, GA
Jim
2018 Mustang GT 10R80 PP1
Long time lurker, recent member, first time poster here - interested in documenting my recent experience as well as looking for some advice/thoughts from the group.
I have a 2018 GT with the 10R80. I bought it new in April 2018 (build date 11/17). The car is very well taken care of, lightly driven around town (1-2 times a month on the interstates around Atlanta and has been from Atlanta to Charleston, SC and back one time), and has never been on a track or drag strip. No tuning or performance upgrades - essentially stock. No accidents or major issues other than a tire puncture (left rear tire replaced by local tire shop under extended warranty - no damage to the car, but the tire sidewall was damaged due to driving with low tire pressure - I have my doubts that it really needed replacing right away, but I paid for the extended warranty, it was no cost to me, and why risk tire failure, but I digress...). Other than the tire issue, it's only been serviced at the Ford dealership. Occasional sport mode driving (transmission and exhaust) for fun. It ticked over to 7,750 miles in early January of this year.
The car had a transmission issue in April 2019 - pulling away from a red light leaving work on a Friday night - hard but not excessive acceleration, it seemed to miss at least one or two low end gears, went into limp mode, and the service engine/wrench light came on. I pulled over, turned the car off, and let it sit for a few minutes. Started it back up and it drove normally, but the check engine light stayed on. Drove it home, made a service appointment for the next Monday and let it sit all weekend before taking it in. The dealership service department checked it over and performed a software update/reset which seemed to resolve the issue. Since then, I've been very diligent about paying attention to how the car shifts gears. It hasn't been overly rough or jerky, but it would occasionally hesitate in the low end gears - almost like it was having trouble making up its mind about which gear it wanted to be in - but no other major issues (no hard shifts, check engine/wrench lights, etc).
Until Thursday, Jan 9 - I was leaving work under normal circumstances (5 o'clock traffic) and was simply pulling out and accelerating into traffic - a little firm on the gas but not flooring it - and the car was in normal drive mode. I thought at first I was having a complete deja vu of the same issue I had last April - the car missed a shift in the low end of the gearbox, went into limp mode, it was even in nearly the exact same spot on the same road as before, except this time, after I pulled over, turned it off and let it sit for a few minutes, and restarted it, it continued to have problems - hard/delayed upshifts and downshifts around gears 1-3, hesitating, check engine light/wrench on. Got the car home, made a service appointment the following Monday (car was parked all weekend again but was still shifting roughly on the way to the dealership). I could get the car to move more smoothly if I put the transmission in sport mode and used the paddles to get up above 3rd -4th gear (actually drove pretty normally above 4th gear). I did some research on these forums and other resources online and suspected that my car was having issues that closely matched those described in the Ford service bulletin SSM 47361 (posted in this thread - https://www.mustang6g.com/forums/threads/2018-10r80-a10-most-recent-tsb’s-in-here.102918/#post-2336328).
Long story short - the car has been at the dealership since Jan 13 (after the initial evaluation, they could only tell me transmission failure, needs to be torn apart, damaged parts replaced, etc) - I've been patient but have been on them for updates in the last couple of weeks as well as been in contact with Ford corporate regional customer service rep as the car has been out of commission since Jan 9 and at the dealership for 30 days as of today. This morning I got word that the parts we were waiting on (torque converter and seal kit) finally came in, and the car should be fixed in the next day or two. Also got the final word from the service advisor that the one way clutch failed confirming my suspicion that my car was most likely affected by the same problem listed in SSM 47361. It's an early 2018 model, and the reports I've seen from others seem mostly to be reflected in those cars with relatively low miles - fits my car's pattern pretty closely.
My two questions for the group are basically this - with one way clutch failure confirmed and missed/jerky low end shifts in the 10R80 being a previously reported issue for my car and a small number of other 2018 models with 10R80s in general:
1) Do you think I just got bit by this problem because of the relatively low miles on my car causing it to take a longer time to get to its "failure" point?
2) Could the previous issue I had with my car (April of last year with the missed shift, software update, and occasional "funny" shifts since then) have been an early warning of imminent failure (can't remember how many miles were on it then - probably around 4000-5000 miles)?
Other than reporting what I've experienced to the group (happy to answer any specific questions or clarify any info I can if it might be helpful to anyone here) - I'll be happy to upload any reports from the service dept once repairs are completed and I have the car back.
Thank you for being a great resource for fellow Mustang owners and for any thoughts.
Jimmy
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
I'm always puzzled when I hear about dealerships doing that. And I seem to hear it more and more often these days.
If I have learned something after working in IT for more than two decades, it's that software doesn't go bad. It either works, or it doesn't. There's no way a piece of software can work for one year and then suddenly stop working. Software doesn't break.
If the transmission misbehaved from day one, then you might suspect a software glitch and might hope to fix it with an update. But if it works fine for one year and only then starts misbehaving, then there's absolutely no doubt that it has nothing whatsoever to do with the software, and that any technician suggesting that is either incompetent, or taking you for a sucker, or both.
Yes, I'm pretty sure it was.
Rash
Cary, NC
2018 Mustang GT Magnetic/Showstopper Red, 401A, Active Exhaust
A reflash will update to the most current software version. If Ford updated the PCM software, it could improve things. It did for me (fingers crossed, knock on wood).
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Sure, a software update can (and usually does) improve things. What it cannot do is fix problems that have appeared out of the blue.
If something works perfectly well for a long time and then it suddenly doesn't, that's definitely not a software issue.
^^^^ Exactly.
That’s why I’m saying if after a “software” update via Ford IDS a 10R80 is still shifting or functioning abnormally - it’s a mechanical problem.
