GT350 Engine Refresh Time!
honeybadger
honeybadger
Just don't care
COTA
Kevin
Update. Got a call and the heads are being 2nd-day aired back to RGR for clean up and to be put on the flow-bench. Seriously top notch customer service from Aaron and the rest of the crew. This is awesome and definitely relieves a lot of stress.
Dominator961
Midwest
Scott
18 GT350R
Editing this post so everyone keeps the pitch forks at bay. JPC/RGR are taking care of everything.
Got the heads back from RGR last night. Some surprises.
Heads were decked and polished. The valves look mighty purrdy.
Nice and clean exhaust ports and mating surface.
New PAC Racing valve springs and Ti retainers are in
Peak at the bronze guides
New FP valves I mentioned earlier in the thread
Now to the surprises. First, combustion chamber wasn't smoothed/machined. It was polished, but still retains the factory CNC ridges.
Inconsistency in the ports between heads (specifically on the bottom).
When I spoke to JPC/RGR they said it's because the CNC program is set to "port" to specific tolerance and these areas exceeded the tolerance (read: shitty OEM tolerances were too off). That's all fine, but I would have expected clean up by hand after. Exhaust ports on the same head are similar.
Lastly (and most concerning), I was also surprised to see that the heads weren't thoroughly de-burred. The little metal ridge below is similar across all 16 head bolt seat areas. This is how they come from the factory...but I would have expected these to be de-burred. Not super into the idea of putting this on a recently re-built short block.
Sigh...not entirely sure on the path forward. My gut tells me I should de-burr those and leave the rest alone until Tim at MPR gets my entire long block for a refresh in the future. Thoughts? If agreed on de-burring, recommendations on tools/methods?
I expected a bit more for ~$4,500. No blueprinting documentation/flow numbers were included either. Ugh.
Thanks, ya'll!
I am so fucking tired of every aftermarket business (whether it’s suspension, engine, drivetrain, interior, etc) always saying how bad oem tolerances are.
News flash!
I worked in tool and die for 15 years as a journeyman. And I’m here to tell you our tolerances are WAY higher then any aftermarket shit.
I can buy any oem part and it’s going to fit my car as designed. Now if I go buy 2 roll bars for example and install each one in my car, both will fit differently. That goes with all aftermarket parts.
Stop blaming the oem for your shitty ass workmanship. No aftermarket has the funds or resources as the car manufacturers do.
Sorry, but to say their cnc program only does this or that and to blame the shitty port work on the oem cnc head work is LAME!
That head port smoothing is done by hand. Not cnc.
Dominator961
Midwest
Scott
18 GT350R
That’s why most of these places are fly by night. I’ve been doing this for over 30 years. I’m sorry you’re experiencing it now. Nothing’s changed in all these years with some of these shops.
Some shops don’t even do their work. They just advertise and take the credit. That is until something goes wrong then rhey blame the actual one doing the work.
fpa1974
GA
'19 GT350R
That is the right thing to do. I wonder if you posting it here had anything to do with it...
honeybadger
honeybadger
Just don't care
COTA
Kevin
Definitely wasn't my intention. When I spoke to them before I left the conversation mostly thinking I should have asked more questions before sending the heads out. No bad feelings.
Very grateful for the their Swift action and excellent customer service.
Tank
9/11 - Never Forget
Above the Notches
G0853
That's awesome assuming you're both on the same page for what needs to be done....:lipssealed:
honeybadger
honeybadger
Just don't care
COTA
Kevin
When I built my Boss motor, starting from a bare block... I was surprised at how much machining was lift "dirty" and I did get a small file to knock everything off prior to assembly.
Damn that's scary stuff to see. I'm convinced this is the type of thing that went through my oil pump gear.
honeybadger
honeybadger
Just don't care
COTA
Kevin
Just got a special delivery. Everything looks absolutely perfect. Will post high res photos tonight after work. Totally drooling right now.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
I always LOVE seeing pretty and expensive engine guts, that soon will never see the light of day again.... :inlove:
honeybadger
honeybadger
Just don't care
COTA
Kevin
Ahhh screw it. Meeting moved and I ran out to grab a few shots. Work is very well done and the parts sure are purddy. Can't wait to put it through hell :)
The Callie I-Beam Billet Connecting rods look stout as sh**
Very clean
Nice long-skirt Custom Diamond pistons.
Some machine work on the crank
So beautiful!
Tons of little areas where burrs were removed :)
honeybadger
honeybadger
Just don't care
COTA
Kevin
honeybadger
honeybadger
Just don't care
COTA
Kevin
Definitely been drooling over them. Can't wait to get it back together and put the power down!
Tomster
Beware of idiots
Tom
Engine envy! When I have more free time in a few months (and more money), I plan to seek out a junkyard voodoo and do what you are doing. Impressive.
