GT350 Engine Refresh - Part 2
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Hi all!
The time has come to tear down the race motor. For the lucky few who didn't read through the 35+ pages of the original thread, last winter I opened up my original motor to find out that I had some valve springs chip and send pieces of metal through the oil pump. After much discussion and lost sleep, I decided to build the motor for race use.
The heads went to Rich at RGR for port/polish and valvetrain upgrades while the Shortblock went to the wizard called Tim at MPR Racing Engines. The motor was assembled to race specifications with many beefed up parts to minimize rotating mass, friction, and handle high heat. As such, the life of an engine like that is ~40 hours (per Ford's service recommendations).
We're at 42.5 hours on the clock of heavy race-environment use, so time to tear into it and see how things are looking and what needs to be freshed. I'll for sure be putting in fresh timing chains, guides, tensioners and valve seals (it's burning some oil on startup). Other than that, hopefully it'll be in good shape and we won't need to worry.
UPDATE: Added teardown video. Keep reading on if you prefer pics.
So valve covers off - the cams look like they did when I put it back together. No new wear that I'm able to see on the lobes.
Front engine cover off. Nothing out of the ordinary at first sight. Chains look good. Tensioners are holding tight, etc.
Cam phasers look great
Chains off. The ends of the cams look good. This bottom black bracket/guide of the secondary tensioner has been a worry for me. Replacing with the upgraded GT4-spec guide upon reassembly
Secondary chain tensioner showing some wear. Definitely time for replacement
MMR Guides showing some indentation from the billet tensioners push on the guides
. Looks like I'm going to pass on these. Don't need these bits of AL floating around in the oil
The guides are showing some extraneous wear on the ends. Evidence of some play in the chains.
Pulled off the oil pan to find that my FP350S Oil pickup tube had a broken mount. That's not good. That was a ticking time bomb. Mount half was freely spinning - pickup tube only held in by 1 bolt. Seal to pump was ripping. Ooof. Going to have to reach out to Watson/Ford Performance about this one. This easily could have been a $15,000 accident.
On the bright side, I popped the main caps. Bearings looked good. Will measure later this week
Popped a couple of rod caps. Bearings look great here too.
Opened the oil pump and looks pretty normal from other pumps I've seen. Finger nail doesn't catch
honeybadger
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I'll grab some detailed photos of the heads, valves, and cylinders tomorrow. Cylinders look great. Some wear, but nothing I'm worried about given the abuse. Stay tuned.
TDC
Long Island
2016 GT350, 2019 Challenger Scat Pack Widebody, 2019 Corvette Grand Sport
Great thread; a holiday gift from the Badger to Mustang6G :thumbsup:
Regarding the black bracket guide for the secondary tensioner you are worried about, is it the original?
honeybadger
honeybadger
Just don't care
COTA
Kevin
'17 GT350
  • Like
Reactions: TDC
loco_GT350
Tempe, AZ
2017 Race Red GT350
Love your engine posts, these are awesome. Any chance when you do the reassembly you can do a step by step video showing how to do the timing chain install? I have seen step by step timing chain installation videos for the coyote but none on the voodoo.
JAJ
Vancouver BC
2016 GT350 Track Pack
Pulled off the oil pan to find that my FP350S Oil pickup tube had a broken mount. That's not good. That was a ticking time bomb. Mount half was freely spinning - pickup tube only held in by 1 bolt. Seal to pump was ripping. Ooof. Going to have to reach out to Watson/Ford Performance about this one. This easily could have been a $15,000 accident....
You have to wonder if having the oil pickup molded into the factory Voodoo oil pan wasn't actually a sensible and well-engineered response to the Voodoo vibration. From the looks of it, the vibration killed the race pickup bracket, which was designed for a CPC engine. After all, what else is there down there to damage it?
It's possible that vibration could be a problem if someone puts a new GT500 oil pan kit on a Voodoo without converting it to a CPC at the same time.
honeybadger
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Sure thing. It'll be a bit different than the usual one since the sequence is a bit different when taking the chains off, but leaving the heads on vs. complete reassembly. But I'll point out that I can.
You echo my thoughts exactly. Ford Performance claims this is safe for the FPC, but it might be introducing harmonics/vibrations that stress the part enough to justify some design changes. Not entirely sure what path going forward yet, but will know more when I talk to Ford on Monday. Will either work with a local machinist to modify this one or have Ford replace it (second choice is preferred).
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
Is that a crack in your block ?
honeybadger
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Yeah. It’s been there since I took the engine out the first time last year. It’s non-structural and regarded a nice to fix, but not critical.
Next time the block is stripped, I’ll have it welded. Until then, send it
Austinj427
CO
2017 GT350
Nice videos man. I just watched them in the other thread.
Those MMR tensioners are concerning too. Glad you are ditching them.
Do you think there is a way to bush the pick up tube support bolt with a grommet to aid in vibration? Or is it pointless?
