Sound tube delete. Help needed
jt021119
New Jersey
Joe
2015 Mustang GT
Just received my PP2 kit from Summit (missing the throttle body hardware, but thats a different story). There is no way I am gettting my hand down in there to plug the hole, so I'm not sure im going to be ripping the tube out as my car sits outside and would not want any water ingress. Has anyone just capped it off at the picture shown? Seems to be a much simpler solution, and if so what exactly did you use? Thanks for any help and info!
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec
Its not too bad. I put the plug in, and I am 6'3" 285#. It was a pinch but I got it done... Took a bit of contortionism :) And absolutely make sure car is COLD :)
luc
2017 GT with PP
You can easily plug the hole from the inside. It’s just behind the gas pedal which is very easy to remove
jt021119
New Jersey
Joe
2015 Mustang GT
I was out there for a half an hour. There is no way my hand is fitting down there with the strut tower assembly. I do not want to remove the assembly due to fear of snapping off the studs (read too many horror stories). I would rather just cap it off at the halfway point. Seems way easier
green97probe
Monongahela, PA
Jim
2018 Mustang GT, 2019 Edge SEL
I think you can use one of those rubber covers that are meant for the bottom of chair legs to cap it.
Pistol_91
Clearwater
2020 mustang GT
I blocked mine at the firewall. Its doable, just tedious because there isn't much room. I didn't want some ugly things hanging around in the engine bay. I figured I'd get rid of it once and for all
LCK22GT
Michigan
Larry
2022 Mustang GT / 2021 F150
I’m a big guy with big hands. I have the strut tower brace too. Once that tube is out you have room. I stood alongside the driver side facing the front bumper. Reached down with plug in right hand, lubed with Vaseline and was able to shove it in place.
LCK22GT
Michigan
Larry
i did loosen the tower brace and removed the engine cover, but didn’t have to mess with the steel cowl support.
MAGS1
Somewhere in Middle America
2022 Mustang GT
I was able to plug mine with the strut bar and cowl brace. Tight fit for sure but very doable. I’m not a small person either. Facing towards the rear of the car, go in with the left hand. That was the easiest for me and I’m not left handed.
Kabayo
Las Vegas
David
2023 Mustang GT
I was able to do it with my left hand, facing the back of the car. To much body English required for right hand.
I’m a big guy too. I took a long piece of tape and stuck the back of the plug to the tape. Then just the the tape dangle down until the plug was at the hole. At this point simply slid my hand down and pressed the plug into the hole. Easy piezy.
Bit-Image
Kansas
Jeremy
2022 Mustang GT Premium
I had a difficult time with this too. I was able to access the firewall bolt from underneath using a 1/4 ratchet and a U joint. I then was able to remove the tube and get my hand into position to press the firewall plug in from the top... Not easy, took 10x longer than I thought but I patients paid off in the end.
Sketcham
Vermont
Shaun
2019 GT Vert orange fury
I did what you want to do. I capped it there as in your photo and at the air intake tube. Works fine, less hassle. I used rubber cane/crutch tips. Saved the removed section to replace if I sell the car.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I will be doing mine in a couple days. I heard things are much more accessible from below when your car is jacked up. Wouldn't that be the easiest way?
MAGS1
2022 Mustang GT
Literally took me 2 minutes to plug it from up top but if you’re already under the car it should be just as easy. I didn’t even bother to remove the bolt holding the sound tube to the firewall, just give it a good tug and it comes right off.
