Do I go back?
Mach 307
Mach 307
Illinois
Alec
2022 Mustang Mach 1 Premium HP – TR-3160 | 2008 Toyota Yaris Hatchback
SBR70.3
Edmond, OK
2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
Any reason you did not install this yourself? I mean, it is a strut brace. Takes maybe 5 minutes tops to put on.
And how the hell did they cause that many scratches? Was there anything else the shop put on?
Mach 307
Mach 307
Illinois
Alec
Honestly was dropping the car off for other work (installing the GT500 swing) and figured they could do it all at once. I have no clue how they managed to, it’s all they put on.
Mach 307
Mach 307
Illinois
Alec
It’s not a dealership as mentioned earlier, local body shop. I also mentioned earlier I’d be okay with a professional touch up, as I don’t feel it should be on me when they caused it, that’s all.
KingKona
Virginia
Shlomo
2019 GT
I would highly suggest getting some touch-up and taking care of it yourself.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Precisely why I do my own work on anything I'm fanatical about.
kz
West Chester, OH
Mustangs & F150
If they did similar "damage" somewhere in the suspension, would that be similar problem for you OP ? Like underneath the car ?
This is under the hood, they'll look at your really weird when you show up, even weirded when you start talking about it putting it back the way it was (KingKona's question is very valid in this case).
Putting it they it was would require going back to unibody and factory painting it, which is ridiculous to even suggest.
Touch it up or just leave as is.
Also, suggestion to do it yourself above was great. This is as basic of a job as they come.
Mach 307
Mach 307
Illinois
Alec
I get I’m being a bit over the top about it but it’s just very frustrating to come across on a car I bought new 6 months ago. I just would like them to give an honest attempt to make the situation better, and if they cannot I will do it myself. I’m going to go in there very respectful, not going to b them out etc.
kz
West Chester, OH
Mustangs & F150
Your reasonable options are touch it up yourself, leave as is, ask them to touch it up (with understanding that they're going to have their lowest qualified guy take a touch up paint and go at it.
WItoTX
Houston
Kyle
'17 GT350
IMO, once you start putting parts on a car, its going to get dinged. If I want a show car quality, I do it myself and protect everything. I don't expect the exterior paint to get dinged, but engine bay, 100%.
I would touch this up myself if it was me and mention it to them next time to be more careful. My $.02.
Yep. OP, the juice isn't worth the squeeze. Installation takes maybe 15 minutes for the spoiler and STB.
KingKona and KZ have valid points.
Mach 307
Mach 307
Illinois
Alec
Honestly after taking a look again you guys are right. Just really painful to see on my baby. Do you guys suggest I try Dr. Colorchip under there which I’ve had great results with before on the outside? Or the paint pens instead?
WItoTX
Houston
Kyle
'17 GT350
Yep. That would be my bigger concern. Did I just turn a minor scratch, which 90% of people will never know exists, into a molehill, where now there is gobs of touch up paint that doesn't quite match, which also dripped all over.
I just don't see this ending well. The only real reasonable thing, IMO, is to call and say look, I found some scratches under the hood. I apologize, I should have inspected the car before I left. I didn't, that is my fault. I don't know if they are from me, but just in case, I wanted to let you all know it might have happened here. I also noticed some scratches on the strut tower brace. Did you all see those when you installed it? If so, let me know so I can return it for an unblemished STB.
KingKona
Virginia
Shlomo
2019 GT
I can share that the Ford color pens are a freaking mess, but match very well. Just order it from your dealership with the paint-code on the car. Watch YouTube videos on how they work.
Any color black should be close enough on those parts.
Mach 307
Mach 307
Illinois
Alec
Okay thank you. Honestly my main concern is rust so as long as I can get everything covered I’ll be happy, like I mentioned a full respray someday years from now isn’t out of the realm of possibilities for how long I want to keep this car.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
I agree with the majority on this one. Lodge your complaint with the shop - in a respectful manner; then fix it yourself. A few of the scratches look like they could be wet-sanded out. Once you have touched the others up, careful wet sanding will help them blend in. You will take more time and care than the shop and it will turn out better. And it's a good excuse to bond with your car. Nothing stays new forever, but I share your passion to keep it that way as long as posible!
