Vlad Soare
- Jan 21, 2020
- Bucharest, Romania
- Vlad
- 2020 Mustang GT 6MT
The BMS reset tells the BMS that the battery is new. It resets the battery age. This must be done anyway.
If you replace the battery with an identical one, that's all there is to it.
However, the BMS also knows the battery capacity and type (EFB/AGB) and uses this information to devise a suitable charging strategy. If you switch from EFB to AGB and/or to a higher capacity, then a bit of extra programming will also be necessary.
