Replacement AGM Battery?
jwt
Alberta
2019 Ford Mustang Bullitt
Getting low voltage warnings on my battery, low temps are probably exposing a battery that got heavily discharged a few times.
So rather than be let down when I need it most just going to replace the battery. However I have heard that if I change the battery type and Capacity the BCM needs to be reset or programmed?
I have forscan if that helps.
FreePenguin
Ohio
Donald
17 mustang
Ford dealer can program all that with new battery purchase too
Rock&Roll
New York
2016 GT Stick- 2022 VW GTI Stick -2011 HD Fatboy
So if your battery dies you cant just replace it like a normal car ?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Dominant1
Dr Frankenstang
There no reprogramming involved with switching a battery, just make sure you don't cross negative and positive..
Rock&Roll
New York
Thanks for the reply. My car is 5 years old and may need a battery in the future.
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Yes, there is. The BMS must know the capacity and type of battery, otherwise the intelligent charging strategy will be wrong.
It can be done with ForScan, but I don't know the codes.
Dominant1
Dr Frankenstang
My original battery will be 5 years old this July its not showing any signs of old age!!
Rock&Roll
New York
Mine is fine as well and I don't plan on replacing it until it dies but I was curious about the programming thing. I'm hoping that if and when it dies it will be in my garage or I'm parked on a hill so I can roll start the car but I'm not really worried about it to be honest.
Dominant1
Dr Frankenstang
[/QUOTE]
I google it & I saw nothing that said the correct designated battery for our cars needed to be programmed.
frank s
san diego CA
www.fsheff.com
frank
Stang '19 Magnetic, EcoBoost™, Vert, MagneRide® PP
The Odyssey is likely a good replacement, although not precisely the same size as OEM, it will fit without problems, as did the XS Power D4700 I used.
There is at least one thread in this site that makes clear the routine supposedly required upon putting in a new battery. I used Forscan according to those instructions on a previous car/battery upgrade to AGM. I must have found the codes on here somewhere. Otherwise it seems to be important to let the car sit for eight hours or more with everything turned off and the doors locked, after new-battery install.
FreePenguin
Ohio
Donald
17 mustang
My little device I own has a program battery section I assume for our car
scotty
London, Ontario, Canada
Scott
2017 Mustang GT
ORRadtech
Atlanta, Georgia
