Replacement Battery
Andy13186
You could upgrade to a lithium . Im happy with my antigravity atx-30hd. Really tight fit in the OEM battery box and you have to mount it sideways and bend the wire harness connector to connect, but it works. and like 20 lbs lighter than standard battery up high in the front of the car. ATX-20hd would work too and fit alot easier and be even lighter.
May not work for you if you are living in a cold environment, not really sure.
zenwhipper
Seattle
Scott
2023 Mach 1
did you get the core charge refund for the OEM?
I did not. In a curious chain of events, I bought the battery first, put it in the car and then it was not going to work for me to return for the core charge refund. :facepalm:
Garfy
Utah
Gary
2020 Mustang GT, 2012 Honda Fit Sport
It appears that pro-rated warranties are disappearing and everyone is going to a 3yr free replacement.
With that being said, I have had good luck with Duracell from Sam's, and the Ever Start Maxx line from Wal Mart.
Yes, it seems a lot of them eliminated pro-rated warranties. My Napa entry level for one of my cars is 18 month replacement only, no pro-ration. However, the Interstate MTP-96R has a 30 month free replacement and pro-rated beyond that up to 6 years.
barron64
Auburn, AL
2018 Mustang GT convertible PP1, 6sp, 2006 Toyota Tundra Dbl Cab 4x4, 2009 Acura MDX, 2007 Toyota FJ Cruiser
I would be interested in a lithium replacement but...for their cost, you should get at least 6yrs free replacement warranty, or maybe more. How much did you pay for your atx-30hd?
m3incorp
Georgia/Colorado
James
LIke Joe603 and Evolvd, running similar wattage stereo systems. I installed the Costco Interstate AGM H5 (Group 47) 3 year warranty for $189. It fits with a slight lift of the battery cover and provides more power than the 96R stock.
LICobra
Long Island, NY
Tony
2019 GT350 K0933
My 2019 battery finally met it's demise, I went with the 96R-590. The battery swap with the BMS reset was 5 minutes. Great info on these forums.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
I would steer clear of LiPo batteries. The full size models require their own charging management system that does not play well with Ford’s BMS.
ORRadtech
Atlanta, Georgia
Aside from lighter weight what does it get you?
It only has 600CCA which you can get in a flooded battery that's the correct size. And Costco sells it for half the cost. Or a H5/47 (like that lipo) with 670CCA for $185.
  • Like
Reactions: GTP
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
I did the NAPA Legend 96R, $200 OTD.
reset the BCM. Now the gauge runs at around 14V (it s was 14.5 before).
Old battery showed 12.2 volts when sitting and was OEM.
Rather not get stranded .
joe603
joe603
ATL
Joe
2021 GT Premium PP
Summit Racing has the XS Power D4700...there's a store near me; probably going with that.
m3incorp
Georgia/Colorado
James
I go to that store in McDonough when I feel the need to browse auto parts. :)
BlkMach10510
2023 Mach 1 10R80
zenwhipper
Seattle
Scott
2023 Mach 1
I just looked at that battery and put in my car's info and it says it will not fit my car. Did it say the same for you?
I knew it fit from others on the board. It’s not an OEM battery for our car, so it would not show up for fitment.
Scott
