Not Happy with Performance Pack Traction this am
joe603
joe603
ATL
Joe
2021 GT Premium PP
I've been to track events and have pushed the car a bit. I was probably 10mph too fast for the corner. Like I said, my last car was a heavy tank and up until this morning, I felt the GT was on light on it's feet and on rails.
Andy13186
Get on the brakes load up the front tires with weight then start turning
WItoTX
Houston
Kyle
'17 GT350
And to be clear, I am not trying to be a dick with my post. I've done exactly what you described more than I care to admit. Shitty feeling for sure. It's what pushed me to start AutoX and Track Sprints.
shogun32
Northern VA
but the fronts still had tons of tread. It's a 21 with the performance pack...... I have OEM up front
How can you sleep at night having the Trash-irellis on your car?
.the car in OEM tires off the lot had some oversteer. The rear would kick out often
power oversteer is NOT the same thing as designed-in understeer. No factory-stock S550 has oversteer, by the usual and customary definition of the term.
joe603
joe603
ATL
Joe
2021 GT Premium PP
Did that my friend...not enough obviously though. I wonder if the GT350 that I almost bought would have done the same...lol I'm guessing not.
Egparson202
2019 Shelby GT350, 2018 Audi TTRS
Yes. But at a higher speed, and not to the same degree. The Mustang is a heavy front engine car. It’s certainly possible to tune away some of the tendency to understeer. But there’s still physics. Physics is undefeated.
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Now my car is setup with the Ford Performance Track Kit and 19X10 with Mich PS4S up front and 305/35/19 out back and man, you have to be really hamfisted to upset this car. When my car was stock with the PP1 it came with the Mich PS4S and my main complaint on the front end was its lack of feeling up front, not that it didn't grip.
luc
CA
2017 GT with PP
305 on 10” rims ?
slowdown
Howell, NJ
Doug
2015 GT PP, 2021 GMC Sierra 1500 Elevation Duramax
Were you gliding into the turn? Generally speaking for a car to grip on a set you should have just lifted to unweight the car or be under braking so the load is up front and it increases the footprint of the tire
So if you did that and it happened then it’s either tire compound/tread, tire pressure assuming you normally take a set there.
Honestly if it’s something you normally have no issue with it’s probably just a mental lapse and the car wasn’t properly sorted to take the set.
It happens
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
I parked my car next to a Challenger, and TBH, I think the Challenger was overall smaller.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Dave2013M3
El Segundo,Ca
  • Like
Reactions: luc
