5speed
Just a question, if it runs on 87, will run better on 91/93, will it run better on 110? It can be had so should we be running that at the track, etc? Will the computer compensate for that without a tune on it?
turbo 2.0 liter with a bit over 300 hp... im willing to bet Mercedes probably specifically said do not use 87 octane, but that's just a guess. recipe for problems in that type of engine.My brother in law has a leased 2020 Mercedes CLA 35 with a AMG hand built motor, he is extremely cheap and thought he could get away with using 87 octane. He was very wrong! The motor destroyed itself in less than six months. He was lucky Mercedes replaced the motor under warranty.
There, fixed that for you.The peak power difference is irrelevant, where you really lose the most is innormal lazy drivingpart throttle racing. The ECU down low likes to throw a lot of ignition timing to make up for the fact the engine is on the smaller side for a V8. That's the most likely situation to find knock,
Lol, if you say so. Given you live in Arizona, you should be familiar with timing pull in the summer. But maybe not, the Gen 2 cars are lower compression and make less power, so they're probably less affected.There, fixed that for you.![]()
When you say explosive power, what do you mean? Easier to spontaneously combust? or more power potential?if you do a bit of googling, you will find 87 has more explosive power
So powerWhen you say explosive power, what do you mean? Easier to spontaneously combust? or more power potential?
