How does your GT run on regular gas?
5speed
Naples
18GT
Just a question, if it runs on 87, will run better on 91/93, will it run better on 110? It can be had so should we be running that at the track, etc? Will the computer compensate for that without a tune on it?
5speed
Naples
18GT
Anyone of of you more knowledgable gents know the answer? Sunoco 110? Will it adjust to that without a tune? Will a tune even have a setting?
nustang
BC, Canada
2020 GT, performance pak, active exhaust
87 cooler weather. 91 in the peak of summer. Esp in city, where intake air can be really hot, with a better chance of knock on accel.
if you do a bit of googling, you will find 87 has more explosive power ... 91 and up less chance of pre-ignition .. ie not as volatile, but needed for high compression engines. We are conditioned to relate more $ to better. Best grade is what your engine calls for in the manual.
Joedag1
Joedag1
Joe
2019 Mustang GT
My brother in law has a leased 2020 Mercedes CLA 35 with a AMG hand built motor, he is extremely cheap and thought he could get away with using 87 octane. He was very wrong! The motor destroyed itself in less than six months. He was lucky Mercedes replaced the motor under warranty.
331GT
Chicagoland
Dennis
1995 DFG GT vert, 2019 Oxford White GT PP1
turbo 2.0 liter with a bit over 300 hp... im willing to bet Mercedes probably specifically said do not use 87 octane, but that's just a guess. recipe for problems in that type of engine.
Andy13186
Never ran regular even once, my car had 42 miles on it and a low fuel level when I bought it they offered to fill the tank with 87 I denied that. Put in 93 then got tuned for e85 around 10k miles now I have 50k miles whippled 770 rwhp and run e50
Linkster1666
AZ
Link
2019 Mustang GT Premium Orange Fury PP1 A10 401A 3:55
It doesn't!
mc68386
Arizona, USA
2017 GT Premium
The peak power difference is irrelevant, where you really lose the most is in normal lazy driving part throttle racing. The ECU down low likes to throw a lot of ignition timing to make up for the fact the engine is on the smaller side for a V8. That's the most likely situation to find knock,
There, fixed that for you. :crackup:
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Lol, if you say so. Given you live in Arizona, you should be familiar with timing pull in the summer. But maybe not, the Gen 2 cars are lower compression and make less power, so they're probably less affected.
geezer stang
Birmingham, AL
2017 mustang gt,base
i'm on a mixture of 87-89-91,for the type driving i do it works out for me,haven't noticed any pinging or loss of power.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
It doesn't run regular. It can't anymore either.
Johnnybee
Canada
2018 convertible
Not a GT, but have run 91 since new, but with the price of it now am thinking about dropping to 87 as well. It just annoys me that there is usually a 30 cent leap between the two grades but only another nickel to 93. The spread has just gotten bigger and bigger over the years. 91 is now in the vicinity of CDN$2.25/litre or roughly $6.60/gallon for my US friends.
Linkster1666
AZ
Link
Sure, the manual says IT WAS DESIGNED FOR 87 OCTANE, it was. The manual doesn't say it runs BETTER on 87 than 91/93, it just says you can USE it, and it's fine, which it is.
Will I use 87 Octane in mine, F*CK NO!! Not because 87 doesn't work, but because it doesn't work as well as 91/93.
How well does it run after 100k mile on 87 only? On 91 only? We shall see.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
When you say explosive power, what do you mean? Easier to spontaneously combust? or more power potential?
