How does your GT run on regular gas?
69mach1-395
central nm, usa
2016 RR GT/CS
That's a good point. The LS is very low tech compared to the Coyote. Cam timing can only be adjusted as an entirety rather than intake and exhaust getting separate adjustments. So there is less flexibility WRT dynamic compression ratio.
I'm sure they ran multiple sessions over and over and averaged them. That's typically what they do. Basically it means that the engine didn't knock on 87, so 93 was the same.
So how much a Coyote gains depends on how much it knocks on 87 (or how much it has to adjust from peak power settings to remove knock with 87). If it doesn't knock when running 87, then it won't gain anything with 93. I've always said I think on a hot day there might be some benefit, but when it's cold you won't notice. But I could also believe 20 hp, since 5% is a small enough change that I might not be able to tell a difference.
That was their basic conclusion...if an engine runs fine on 87, then more octane does little to help. The only noticeable gain was from e85.
Hack
Minneapolis
Mustang, Challenger
Agree. The variable is that the Coyote variable independent cam timing can bleed off compression by opening the intake later or closing the exhaust later. Plus direct injection helps to prevent detonation by injecting the fuel as late as possible. So basically the Coyote has control of its functional compression ratio plus there's no fuel to detonate until it's time for the combustion event to occur. 12:1 generally is a little high for 87, but between DI and the cams, the Coyote might run fine on 87 with 12:1 CR.
TonyNJ
Northern NJ
www.instagram.com
Tony
Just started putting it in my 18 GT recently because of the prices. I drive less aggressively also to conserve a little and not push the engine on the low octane. No problems about 2 tanks in. 🤞
Jerry Carguy
Michigan 48169
Jerry
2021 California Special Black exterior
We have 89 octane here, a nice compromise, runs great. I am not concerned about the price one way or another because being retired, a tank of gas lasts me a month or so.😁
Bikeman315
Myrtle Beach, SC
Ira
OK, just looking at cost I don't really get it.
A Shell station in your neck of the woods charges $4.62 for mid grade and $5.02 for premium. A full tank of gas would only be $6.00 more for an entire month. That's $0.20 a day.
I'm not telling you what to do, that's your business. Just wondering what the logic is.
ReceRed5.0_I.T.
Baytown Tx
Willis
2015 Mustang GT
87 when I just drive around normal and daily drive which is 5 days a week. I have a SCT x4 also and just download the 87 octane tune. Now when I know im going to go to the track ill run all the 87 out, put in half a tank of 93 and download the 93 octane tune.
TonyNJ
Northern NJ
www.instagram.com
Tony
C'mon Bikeman315. That's 2 phone calls in a payphone. That's a lot.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
the kids will never figure out how to operate it!
Point to your analog wristwatch and say 10 bucks if you can tell me what time it says (put it a hour ahead first incase they cheat). Tell em 10 bucks if you can read this paragraph written in cursive. Tell em 10 bucks if you know the correct change if something costs 13.35 & I give you 20.35 etc., etc.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
My favorite is giving a $20 bill and 27 cents to the drive through kid and the deer in the headlights stare back…
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
Hack
Minneapolis
Mustang, Challenger
I wonder what will happen to expressions like "drop a dime on someone"? Will people keep using it even though they have no idea why you would drop a dime?
