GT350 Engine Refresh Time!
honeybadger
honeybadger
Just don't care
COTA
Kevin
Awhh, yeah. #ProgressPics.
Broke some stuff, fixed some stuff, sealed up an engine. #NailedIt
Tractor Junk
Clarksville, TN
Spencer
18 GT350R, 16 GT350 FPRS #3, 2014 Boss 302S
Looks great! You know you’re on the right track building a race car when it makes you question some life choices along the way.
honeybadger
honeybadger
Just don't care
COTA
Kevin
Engine is fully-buttoned up (as much as we can on the stand). Dropping onto the cradle now to install the clutch, flywheel, long tubes, trans, etc.
LAPTIMZ
NorCal
GT350
Bravo bud, are you still waiting on the oil pan or did you decide against it?
autobahnGT350
Northern Virginia
2016 GT 350
Really can’t wait to see how much HP those heads provide. This build is probably going to be a game changer template for others looking to add extra HP, since all we have now are boosted, headers, and/or a tune.
Dominator961
Midwest
Scott
18 GT350R
Did you ever dyno the car before the engine tear down / rebuild?
If so, will you be using the same shops dyno?
Dominator961
Midwest
Scott
18 GT350R
Don’t expect to much of a HP gain. My guess is it’ll be in the 530-540 rwhp range.
Most of what he built is for durability.
The long tubes, tune and if he runs higher octane (not sure what fuel he’ll be running) will provide the most hp gains over the mild head port / chamber clean up. These voodoo heads are already oem cnc ported.
wldtang
Missouri
David
2017 GT350R
First, al]wesome build, this is helping me with my voodoo tear down and assy.
When you install the headers would you mind taking a couple of measurements?
I’m looking for total width were the collectors connect to mid pipe?
I’m putting a voodoo in my 65 fastback and trying to determine how wide s550 headers sit.
Dominator961
Midwest
Scott
18 GT350R
That all depends on header brand and chassis.
Voodoo headers are the same as coyote headers.
You can use any coyote header on a voodoo.
wldtang
Missouri
David
2017 GT350R
I understand. I’m trying to determine if s550 headers will fit between the frame rails of a 65. I don’t know the width of s550 frames.
Dominator961
Midwest
Scott
18 GT350R
My point is why not use headers for a coyote swap into a 65 Mustang?
wldtang
Missouri
David
2017 GT350R
I don’t like the brands out there.
I was going to put a 4.6 in it with 03 cobra kooks. They fit but I changed directions. So I am wondering if off the shelf s550 headers will fit.
Dominator961
Midwest
Scott
18 GT350R
I’m sure Nick at ARH (American racing headers) can hook you up for your swap.
I’ll dm you. I don’t like that we’re hijacking honeys thread. Sorry.
honeybadger
honeybadger
Just don't care
COTA
Kevin
Welp good news and bad news (mostly bad news).
We got the engine in, drive shaft in, and ARH exhaust system installed. When we started the beast, it ran fine for about a minute and then when I applied a small amount of throttle and it fell on its face (sputtering, almost died, etc.) and then threw a p0025 code (B" Camshaft Position - Timing Over-Retarded (Bank 2)).
When we were assembling, we had a bit of a problem with one of the cam phasers and I had to take it apart. Guess what camshaft is throwing the code? Yep - same one.
At the moment, we're planning to order a new phaser. While we wait, we'll do a cylinder leak down test/compression test (to verify valve train and cylinder health) and then begin tear down. Anyone have any additional thoughts/recommendations?
On the the brightside, it sounded fucking savage for about a minute :)
