FORScan Codes - S550 Mustangs
i8iridium
Pat
2020 Mustang GT
Thanks for the reply. The Double Press is what I want. That does not work on my 2020. I see you have a 2019 on your profile did you try on a 2020?
The default as built data for my VIN at 726-37-01 does not look like the as built data before 2020 at that line. So I am assuming Ford moved the location.
I guess it could be an error on my part.
Has anyone got this to work on a 2020?
Thanks again
Jim
The 2020's is 726-62-01 x*xx xxxx xxxx Panic Button 0=Disable 1=Double Press 2=Stock
JJSSI
St Simons Island, Georgia
Jim
2020 EcoBoost HPP w/Handling Package, 2004 Boxster S, 2013 Jeep JK,
Great!
I will try it out.
Thanks,
Jim
Elp_jc
None
2020 Mustangs changed, but not sure which modules. The line above changed A LOT. I know Litvinup, the FORScan expert over F-150forum was working on FORScan codes for the 2020 Mustang, but don't know if he finished, or still working on that. There's very little even for our older Mustangs. Several codes are the same as the F-150, fortunately. But many more are not. And absolutely nothing worked on my digital display. I wanted to see if the 2020 display is the same, and check if somebody could figure out a way to add digital numbers to the coolant temp display. I'd settle to just get that done :D.
FreePenguin
Ohio
Donald
17 mustang
Thanks! I will edit my car today. Does battery dc’d reset any forescan codes ever? Or only flashing does.
Disabling those door chimes today!
FreePenguin
Ohio
Donald
17 mustang
Yep, and start-up chimes too, which are quite annoying as well. Change IPC 720-01-02 to xx0x x2xx. The '0' is for the door chimes, and the '2' for the start-up chimes. Hope this helps.
What do I change those two digits to?
To 0 and 2? Just clarifying that change will disable and not that’s what they are currently
JJSSI
Jim
Works great.
You don't have a list of others do you?
I have searched the net for hours trying to find that code.
Thanks again.
JJ
FreePenguin
Ohio
Donald
17 mustang
edit
I did it, thank you guys so much. So much better not hearing beeep beeep beeep
i8iridium
Pat
2020 Mustang GT
Works great.
Thanks again.
JJ
It depends on what you're looking to do. I haven't gotten though everything yet to see if it's valid. And it's only BCM. As far as the other modules, the other Mustang Spreadsheets are still relevant.
Elp_jc
None
You change whatever you have in those fields TO those digits :D. But seems like you got it, right? Glad I could help :). Nice to have the car nice and quiet, without annoying chimes.
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
What happened to the spreadsheet? It comes back as 'deleted or wrong address'
Elp_jc
None
I have both (F-150 and Mustang). Just checked them, and they work. Couldn't post both (too large), so I'm attaching here the Mustang one, and will try the F-150 on another post. Hope this helps :).
EDIT: Couldn't post the F-150 one (still too large), but go to F150forum.com, and it's on the first post of the FORScan sticky.
ScubaSteve2020
Dublin
2019 Race Red Mustang GT
I want to confirm the rear sequential turn-signal disable for my 2019 Bullitt worked. MUCH brighter than stock, since all 3 LEDs light up at once, rather than just 1 at a time. Plus being only at the rear made no sense to me anyway, so happy to have much brighter (and safer) turn-signals now :D.Hope this helps others. Here it is:
BCMB 7B7-03-01 x0xx xxxx xx
I wonder if changing that 0 to a 1 on the EU Mustang would 'enable' the rear sequential turn-signal
michail71
2018 GT 401a A10
I get blinded by other mustangs with the normal turn signals as is! It's like looking into the sun, lol. I can't think of another car with brighter tail lights and turn signals besides EMS vehicles. I shield my eyes now by habit when closing my trunk.
Elp_jc
None
Only one way to find out :D. Easy to change back if they don't, but I suspect there's a module for that. Let us know if it worked.
And as far as too bright turn-signal/brake lights, I don't think so. Have seen others not only brighter, but MUCH brighter than ours. Some Cadillacs with giant tails, and some Chrysler cars, with retina-searing intensity, among others. At any rate, the front turn-signals are too dim IMO, which I didn't like, but nothing I can do there. But the rear ones are more important IMO, so all is well now :).
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I would really like it if they started making North American cars with strobing panic stop brake lights (like some motor bikes have) and a braking indicator on the front of the car. I can't tell how many times I've been waiting to turn left through an intersection and I have to play the guessing game if the oncoming car is going to stop or be a red light runner.
