Vlad Soare
- Jan 21, 2020
- Bucharest, Romania
- Vlad
- 2020 Mustang GT 6MT
For sure there is a chance to change things for the worse if you make a mistake. But the changes are easy to undo. You can easily back up a module's configuration before changing it, and restore it later on if you don't like the results. Or just go back and revert those particular changes manually, if you can remember the previous values. No harm done.I am intrigued and scared of changing the codes. Can things be changed which will make the can unusable?
The only thing I can think of that might do any actual damage if done incorrectly is uploading a new firmware version into a module. But you don't need to use this feature. Just stay away from it and you'll be fine.
