Forscan Drive Mode values 2016 S550
BlownCoyote
Berkshire County
2016 Coyote Blown
Does anybody have accurate values to program the drive modes from base to sync 3 upgrade? Also instructions on how to program modules if necessary? I’ve gone through the old threads from 5 years ago. The links to the spreadsheets are dead, or the spreadsheets only contain values from the 2018 model forward.
m2016v6
AB
2016 V6 Base Convertible
These are the values I used when I upgraded my 2016.
Factory NAV owners - if the compass is backwards check this in the APIM.
Manual Transmission: 7D0-01-02 xx9x xxxx xxxx
Automatic Transmission: 7D0-01-02 xx0x xxxx xxxx
7D0-01-02 x0xx xxxx x0xx - Non-Nav
7D0-01-02 x2xx xxxx xAxx - Nav
Base->Sync3 Swap, Enable Drive Mode Toggle EB&V6
ABS 760-02-02 : xxxx 1xxx
Base->Sync3 Swap, Enable Drive Mode Toggle Part 2
IPC 720-06-01 : xxxx xxxx x8xx [Enable - must enable one of the above Drive Modes first]
Lights - Fog Lights Stay On when using Turn Signal
BCM 726-28-02 : xxxx 0000 xxxx
Lights - Simultaneous High Beams & Fog Lights (Enbale/Disable)
BCM 726-27-01 : xxxx xxx? xxxx [Change ? To: 0 - Enable (on), 1 - Disable (off)]
Sync 3 - Adds HD Radio Available on radio settings screen (if radio HD capable) Note: Useful if you have swapped equipment
APIM 7D0-01-01 xxxx-xxx3-xxxx [Change to get HD Radio Available on Radio Settings Screen]
Sync 3 - HD Radio Enable (if radio HD capable) Note: Useful if you have swapped equipment
ACM 727-01-01 x0xx-xxxx-xxxx [Change to enable HD radio - (non-HD radios have a value of 8)]
Sync 3 - Radio Station Label instead of frequency (if station has RDS) Note: Useful if you have swapped equipment
APIM 7D0-01-01 xxxx xxxx ?xxx [Change ? To: 1 to enable (turn on) Radio Station Label if RDS instead of just radio frequency]
Turn Signal - Lane Change # of Flashes (quick/temporary movement of turn signal lever)
SCCM 724-01-01 : xxxx x?xx xx [Change ? To: 0-3=1 flash, 4-5=2 flashes, 6-7=3 flashes, 8-9=4 flashes, A-B=5 flashes, C-D=6 flashes, E-F=7 flashes]
BCMB 7B7-03-01 x1xx xxxx Sequential Turn Lights enabled
BCMB 7B7-03-01 x0xx xxxx Sequential Turn Lights disabled
Fix hazard toggle operation:
BCM 726-29-02 xxxx xxx0
Navigation In Motion - Enable/Disable (Note: This will also disable Sirius Travel Link/911 Assist, Vehicle Health Report, and Changes vehicle clock time by several hours)
APIM 7D0-02-01 : x?xx xxxx xxxx [Change ? to: 5-Disable (off-default), 7-Enable (Non-US Region)]
Speaker level out:
727-01-01 xx00 xxxx xxxx
727-01-02 01xx xx
m2016v6
AB
I didn't do the Navigation in motion thing. Didn't care about it. But I for sure got some new drive modes. Also, if you have the base speakers, definitely do the Speaker level out.
