FORScan Codes - S550 Mustangs
BWG
Laurelville, OH
Greg
2018 Ford Mustang GT, 2011 Nissan Versa SL, 1989 Pontiac Firebird Formula 5.7
Anyone confirm this unconfirmed on an 18 Base GT to unlock drive modes?
2018 LCD Cluster - Drive Modes Enable
FreedomPenguin
Dayton, Ohio
Donald
2017 Mustang Ecoboost Premium, 2013 Scion tC.
Is it possible to remove AM radio from radio sources? I’m tired of cycling through it and getting annoying stuff.
I know you can remove Sirius. Never once have I listened to am in my life
RichBrew
GA
Scott
2019 Velocity Blue EBPP
Hi folks. Looking for some help with a configuration. I want to set up my DRL configuration on a 2019 to be Tribar + Turn/Marker + Fog light. Is there any combination of settings that will accomplish this?
Aussie-up-north
Canada
Lucas
2015 GT Vert
Guys, I’m ready to give up... looking for codes todo the following and hope it’s even possible.
2015 GT twin turbo.
1. Modify auto engine shutdown for 2min (turbo timer)
2. Enable launch control for a auto 6r80 but have it on the break and not the clutch.
vincentjm
Switzerland
Vincent
'15 Mustang GT PP
Are the front amber marker lights always on? Cause on mine they are only used for the turn signals for some reason. Comparing mine with the original as built data shows nothing modified.
I can enable them as my DRL, but they turn off again as soon as I turn my low beams on. Any way of enabling them with the low beam setting?
Rash
Cary, NC
2018 Mustang GT Magnetic/Showstopper Red, 401A, Active Exhaust
Anyone know how to disable the "Adaptive Cruise Control Not Active" message? I have adaptive cruise disabled in the settings (I hate it), but I still get that damned message and chimes every time I turn on cruise control.
Rash
Cary, NC
According to this if I edit the following lines it should disable bass roll off on my base model:
727-01-01 xx5A xxxx xxxx
727-01-02 00xx
What do I change these values to? What exactly does changing these values do to the stock speakers? My subs are currently wired into the rear deck speakers.
Was this ever answered somewhere? Can't find with search.
silverstang9120
Stl
2015 mustang gt
Looking for some help. 2015 mustang swap from 6r80 to th400.
Need to disable back up camera and looking for park on message center. Also my car won’t time out or come out of acc mode so everything stays on after car is shut off.
Rash
Cary, NC
BWG
Laurelville, OH
Greg
The x's represent existing characters in the hex that you do not change. You only change the characters that have different letters or numbers.
If the existing hex is 727-01-01 9999 9999 9999
It says change it to 727-01-01 xx5A xxxx xxxx
The new hex would be 727-01-01 995A 9999 9999
ugstang17
unknown
none
Hexadecimal is just a way to represent 4 binary bits with a single character.
0 - 0000
1 - 0001
2 - 0010
3 - 0011
4 - 0100
5 - 0101
6 - 0110
7 - 0111
8 - 1000
9 - 1001
A - 1010
B - 1011
C - 1100
D - 1101
E - 1110
F - 1111
Finally someone who knows conversion. I convert my age to hex (dec - hex) so it sounds younger...works until I hit A-F in the count sequence.
I.E. = 40 in decimal = 28 in HEX or 00101000 in binary. LOL!
Randhawa_KS
Melbourne
KS
2019 Mustang GT OF vert, FG XR6, Lexus RX 350
As Line Lock is disabled in Aus models, any info on how to enable it on 2018-19 GT Auto Aus models through FORScan would be appreciated or if it is already mentioned somewhere else on the forum please post the link. I’ve seen somewhere on this forum to enable line lock on the 2017 GT manuals for EU/AU models but not on 2018-19 models. Thanks in advance.
TheReaper
Mobile Al
Jesse
2018 Shadow Black GT
Does changing settings in Forscan affect your warranty in any way ?
