FORScan Codes - S550 Mustangs
redtrack
P.R.
2018 GT PP1 10AT
@ddozier, I looking for the same on magneride on similar reason on a 2018 GT
NotMarc
Earth
22 Mach 1
Does anyone have the code to reduce the volume coming out of the 2 rear speakers when backing up for 2018 and above?
The 2018's are so loud!
Thanks
I came here looking for this as well. I have disconnected my battery a few times to do various jobs on the car and it seems like sometimes it's piercingly loud, and others its more reasonable, but it could be all in my head.
chicklet
Atlanta, GA
I'm a CHICK!
18 GT
Thanks
Its in google docs under the 15-17: https://docs.google.com/spreadsheet...SN7v6AjN_t9rWvz0npQpcBbU_u0/edit#gid=53101868
Vehicle Chimes Location (where vehicle chimes are heard from)
720-01-01 xxxx xxx? xxxx
Change "?" to "0"
"4" is default.
frank s
san diego CA
www.fsheff.com
frank
Stang '19 Magnetic, EcoBoost™, Vert, MagneRide® PP
Today the LOUD backing-up sound became not-that-loud and emanated from the front of the car. The only difference I saw was that this time my seat belt was not fastened.
MustangVelocity
BC
Jeff
2019 Mustang GT PP1
Could someone with a 2018—2019 GT confirm that the DRL codes all work properly, using the codes from the 2015-2017's . Thanks!
HoosierDaddy
Randy
I found the info here: S550 Guru - Disable signal hyperflashing and can confirm it turns off hyper-flashing on my 2017 GT premium. Someone else posted this link earlier but I couldn't find the post to thank them.
Does that mean you won't know if a signal light fails? I thought that was the purpose of the hyper-flash.
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
This is the way to disable hyperflashing through FORScan when you use LED turn signals. Alternatively you can disable hyperflashing by using load resistors into the car’s light wiring.
jake_zx2
Kona Blue 2018 GT
A couple new ones from a different thread for activating active exhaust on 2018+ cars without AE from factory
Digital cluster - Credit: @mfoley13
I'm trying the forscan coding to make sure it enables the option on my LCD cluster before I buy mufflers. It seems to be good but I'm not sure.
Previous post gives this:
720-04-01 X*XX XXXX XXXX 4 = Enabled 6 = Disabled
720-10-01 *XXX XXXX E = Enabled C = Disabled
For me, the first line was same but the second wasn't. I had a 1 instead of C but used the E anyway.
720-10-01 *XXX XXXX E = Enabled 1 = Disabled
____________________________________________
Standard cluster - Credit: @Mattusmc
Just finished installing the active exhaust on my 18 PP2, everything works like factory. Plug and play long as you have the harness. Here is the line of code to change in the IPC module if you have a standard cluster.
Inactive code: 720-10-01 0xxx xxxx xxxx
Active code: 720-10-01 2xxx xxxx xxxx
BoostedNate
Tampa, FL
Nathan
2015 Mustang Ecoboost
According to this if I edit the following lines it should disable bass roll off on my base model:
727-01-01 xx5A xxxx xxxx
727-01-02 00xx
What do I change these values to? What exactly does changing these values do to the stock speakers? My subs are currently wired into the rear deck speakers.
MustangVelocity
BC
Jeff
2019 Mustang GT PP1
Verified these on my 2019 GT (Canadian model).
  • Allow All DRL Choices, 726-45-01: xxxx 7Fxx xxxx
  • Front/Rear Parking Lights w/DRL, 726-26-02: x1xx xxxx xxxx
  • DRL Options, lower fog lights, 726-50-01: 04xx
I'll be testing more settings by the end of the week.
dgc333
MA
15 Mustang Ecoboost Premium
I just started playing with ForScan and successfully modified the As-Built to keep my fog lights on with the high beams.
I have a 17 Ecoboost Mustang with the performance package so the boost gauge is in the dash between the vents. This is a pretty useless position for visibility while driving and I was hoping to find a code to restore the boost gauge in the display between the speedo and tach.
I found a listing in the spread sheet that sounds like it will do it for me; 720-06-01 xx7x xxxx xxxx
When I go into ForScan I do not get any labels that start with 720 even though it appears in the As-Built I down loaded for my car. The spread sheet says it's an IPC but that is not a module listed.
Any ideas?
1004ron
Ron
2015 Mustang V6 , 2017 Ford Edge Sport
I installed front switchbacks and side marker and disabled the hyper flash with Foscan.
The turn signal is much more noticeable than stock because it flashes from OFF to bright Amber ON, compared to the stock which flashes from dim Amber to bright Amber.
Turn Signal - Hyper-Flash Disable - the exterior turn signals don't hyper flash, only the dashboard indicator does a double beat.
BCM 726-27-01 x?xx xxxx xxxx Change ? To: 1-on (default), 0-off (no hyperflash) D24112
https://www.ebay.com/itm/7444-7443-Switchback-LED-Bulbs-WHITE-AMBER-Dual-Color-Turn-Signal-Lamp-Light/192443860151?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
https://www.ebay.com/itm/194-50-50-WEDGE-SMD-LED-LIGHT-BULB-PLATE-TRUNK-RUNNING-MARKER-SIGNAL-SIDE-WHITE/372136475766?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
wcharon
PR
William
Ford Mustang GT 2019 Race Red with Package 301A
Does somebody knows if thru Forscan i can activate auto-relock so the locks close every time all the doors are closed? By the way it is a GT 2019 with Enhanced Security package.
Thanks in advance...
