Dissapointing p1x numbers
Jaywebs
Jason
2019 mustang gt. 2019 c7 z06. 2019 rs5
Idk. Maybe Im missing something. 19pp1, p1x stage 2, 4 inch pulley, fore triple pump return style fuel system, off road kooks 1 7/8 headers, e85 verified good fuel, 20 degrees timing, 16lbs at 7850 and only making 718 wheel. Im under the impression that something else is going on i.e boost leak as i feel this thing should be making way more power than it actually is. Or am i completely wrong and expectations too high??? Any body else have a similiar setup to me and if so, what are you guys making.
I Bleed Ford Blue
North East OHIO
718 wheel and you're complaining? Assuming a 15% driveline loss you're at 844 crank.
Jaywebs
Jaywebs
Jason
Again like i said, maybe my expectations are unrealistic. I was under the impression this blower will make 900 wheel with the supporting mods which i have. So in essence, yes i guess i am complaining a bit lol.
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Do you have the 8" (2015-2017) or 7.6" (2018+) procharger crank pulley? Either will fit on a 2018 from my experience.
AZ_whippleS550
AZ
Douglas
2016 mustang GT
sounds low to me I made 700 wheel on 11lbs on race gas through stock manifolds and cats
Jaywebs
Jaywebs
Jason
I believe it's the 7.6.
Jaywebs
Jaywebs
Jason
Regardless the numbers don't really make sense. 718 at 16lbs. 16 lbs should be making 800 plus. 12 lbs should see 700ish.
deanm11
Northern NJ
Dean
2020 Mustang GT A10
I'm plotting my 2020-10spd PX1 build, so while I yet to have direct experience, from LOTS of studying the history here, I think you are right to believe you are low. I think minimum 800 based on your build and timing. Would help to show everyone: dyno graph, log with timing and O2/AF ? Dynojet? 6-speed car ? Dyno in what gear ?
Jaywebs
Jaywebs
Jason
Yes, I agree. I'll have a copy of the dyno on sat and will definitely share with everyone and hopefully someone can make sense of it. Car is a 6 speed and I'm pretty sure was a 4th gear pull as that should be the 1 to 1 ratio. Not sure what type of dyno it is though. As for your build, I can say the p1x is a great little blower. The biggest issue is that you really have to get that thing turning before you get any boost what so ever out of it. Maybe different with an a10. Not sure. If I had to do it over again, I definitely would have opted for a f1a or at least a d1x.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
What kind of Dyno and correction?
Jaywebs
Jaywebs
Jason
Im not exactly sure. Doesnt really matter considering the actual numbers are way far off from where they should be.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
It does matter. I’ve seen some brands and corrections vary by as much as 100rwhp. Find out. My buddy made 840 on a standard dyno jet and then a couple weeks later made 720 on some kind of mustang dyno.
Jaywebs
Jaywebs
Jason
I know there is a difference between the two. I will definitely have to inquire what type it is.
fuelforfire87
IL
2014 Shelby GT500
Definitely seems like the numbers are low, but like others were saying it could be the dyno. Mustang dynos especially are known for reading low. For comparison i made 800 whp on a dynocom dyno with a 4.25 pulley on E85 with a procharger D1SC (about 13.5-14 psi). I know not the same head unit but the P1X and the D1SC are pretty close.
wingnutt
@FL410
michael
350R Procharged w/P1X
they don’t call mustang dynos “heartbreakers” for no reason!
