Crank Balancer snapped off (Whipple 2.9)
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
So I have a 2015 Mustang Gt with 30k miles, with a Whipple gen2 2.9 on a 10 rib kit with Ati balancer with arp bolt. I used red loctite on the bolt and only used a torque wrench to seat it and torque it to 120ft/lbs. I even checked it recently and the balancer was still fully seat and torqued to 120ft/lbs. So the 25th I went wot throttle and at 7600rpm the crank snout broke. Engine shut down by itself and it was quite a noise it made.
Wondering to how many has this happen with forced induction?
Would this happen to a turbo setup?
And where can I get a gen2 longblock? They’re out of stock
rams1919
Ohio
2019 Mustang GT PP1
Shouldn't happen with a turbo setup as there is no external pressure/force on the crank.
As far as a long block, good luck. Unfortunately, they seem to be difficult to find and even more difficult to get accurate delivery timing.
andrewtac
TX
mark
F250. 2020 GT 400A
It happens to turbo as well.
sabtaj1
Bettendorf, IA
Jason
2019 PP1 Mustang GT, 1965 Fairlane 500 wagon
Pretty sure ford has a tool specifically for seating the balancer properly so it doesnt cause any stress to the crank when re installing it. Its like a long threaded stud that screws in completely with a nut and washer to draw it onto the crank. I could be wrong but I would assume the coyote method. Sucks, sorry to hear about the bad luck. I wanted to go 10rib and 20% balancer but holding out.
Red5.0
Houston,TX
15 mustang gt race red non pp
I have seen it happen on a turbo car personally as well.
DougS550
Fishers, Indiana
Doug
I looked for a link to snout break on turbo but can’t find. Do u perhaps have a link ? Thx
Yes, I would like to see the link also. Interesting
WD Pro
United Kingdom
Lime GT
Also be interesting to know if the turbo car had ever had the factory fit balancer removed / replaced.
WD :like:
Jackson1320
California
Jaxson
2015 mustang gt
I’m running a carb legal procharger kit with a 20% overdrive balancer for years now without any problems. I understand that it’s a possibility and I’m ok with that.
7600rpm so did you bounce off the limiter? Or have you Hit the limiter a few times? Hitting the limiter is a very big nono
velocity550
Virginia
Joshua
2020 Mustang GT
Sorry im a bit confused but why would you need a new long block? Wouldn't you just need a new crankshaft?
andrewtac
TX
mark
F250. 2020 GT 400A
I don't have a link, guy local to me. His car was running 8s, so making power.
Red5.0
Houston,TX
Same here.. I don’t have any pictures of the broken snout on the turbo car but it was a big power car running 8s as well and did have an aftermarket crank balancer
andrewtac
TX
mark
F250. 2020 GT 400A
https://www.mustang6g.com/forums/threads/crankshaft-snout-snapped.86800/post-2421610
Another turbo car, user on here; was embedded in a vortech thread, which also had a stock car with 514 miles break the crank.
I am going with a callies for my build, concern was this happening. However it seems to be random, as low power, high power, TT, blower NA, it happens. There is theory that it could be improper install of balancers.
