Crank Balancer snapped off (Whipple 2.9)
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
The problem I have with crank supports is you lose your sway bar.
I have installed a crank support and also have lost the sway bar. But it is not a problem for me.
SolarFlare
S. Fla
2015 CO GT
I have no issue without a sway bar. Car still handles better than 95% of the cars on the road. If you crash without a seat bar….it’s more than likely not the lack of sway bar that causes it
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
I have a 6 rib Whipple with a crank support and did not have to give up my sway bar. I'd love to have the 10 rib, but not willing to give up the sway bar just yet. I believe there is a member on here who has been 8's with the 6 rib so I still have some room to grow. I will say that after lowering the motor 1/2" a belt change is going to be a total PITA.
bankyf
2022 GT500 CFTP
I was wondering if Ford approved the Roush SC , they must have run some harmonic tests with it. In this case there is some back door proof that a belt running a SC is possibly within acceptable Harmonic levels.
My question is, if the kinetic crank stud is a improvement, why wouldn’t they fit a similar fastner when doing a warranty approved Roush ? Could the kinetic change harmonics for the worst ?
I'm not sure that Ford actually warranties the Roush. I believe it may be Roush taking over the powertrain warranty responsibilities.
Jackson1320
California
Jaxson
2015 mustang gt
Veteran
Italy
2020 GT white
Maybe a stupid question, but if the damper can be improved, why hasn’t Ford done so ? They have the skills, so a better domper wouldn’t cost more if it’s just a case of optimising it ?
engineermike
La
2018 GTPP A10
Ford did exactly that in 2018, which upgraded from a traditional elastomeric to a viscous fluid-style damper. Note that the 2018 got a higher rpm limit and, anecdotally, you rarely hear of opg failures in a gen3. However, the cost of the damper increased by a factor of 2-3x. Unfortunately, it appears as though Ford switched back to elastomeric damper (and also got away from the forged timing gear I am told) for 2021+.
Martin5.0sc
Ellington, CT
Ainsley
2016 Whippled Mustang GT
Innovators west, and save crank stud is your friend
shogun32
Northern VA
I'd guess probably because everyone with a Gen3 is looking over their shoulder and desperately afraid of their warranty clause. Come 2023 we might find a rash of failures to equal Gen2 rates.
But you could easily be right. A viscous fluid self-balances to much tighter tolerances than machined and knocks the peaks down a bit.
