Crank Balancer snapped off (Whipple 2.9)
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
ATI strikes again!
olaosunt
Indiana
Shouldn't happen with a turbo setup as there is no external pressure/force on the crank.
As far as a long block, good luck. Unfortunately, they seem to be difficult to find and even more difficult to get accurate delivery timing.
It happens to turbo as well.
Yes sir . Happened to me .
olaosunt
Indiana
So I have a 2015 Mustang Gt with 30k miles, with a Whipple gen2 2.9 on a 10 rib kit with Ati balancer with arp bolt. I used red loctite on the bolt and only used a torque wrench to seat it and torque it to 120ft/lbs. I even checked it recently and the balancer was still fully seat and torqued to 120ft/lbs. So the 25th I went wot throttle and at 7600rpm the crank snout broke. Engine shut down by itself and it was quite a noise it made.
Wondering to how many has this happen with forced induction?
Would this happen to a turbo setup?
And where can I get a gen2 longblock? They’re out of stock
Well hit me up .... might have a spare 😎
LSchicago
Illinois
Lloyd
Too many variables to determine that the root cause stems from ATI balancers.
The one constant variable is that 90% of the time, it is an ATI.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
There variables that are present 100% of the time, such as the stock crank. But then there are variables that play a big role that are not being taken into account such as max RPM, was limiter hit, was balancer installed correctly etc. It may simply be that folks with an aftermarket balancer run thier stuff harder. But without a proper RCA, its all an assumption.
LSchicago
Illinois
Lloyd
It is said most of the time that it was improper installation.
Jackson1320
California
Jaxson
2015 mustang gt
This sucks and I hope op is able to get it fixed soon but I’m willing to bet that the limiter was hit a few times.
Jackson1320
California
Jaxson
2015 mustang gt
A new crankshaft some bearings and a set of valves in the hands of someone who knows what they are doing should just about fix it. Could be fixed as low as $1000-$1500 if he can pull the engine himself. If not add another $500-$1000
LSchicago
Illinois
Lloyd
The fit is tight, and often the balancer bolt torque can be achieved without the balancer seating completely.
This is what I have heard before too.
Epiphany
Global
I like to disassemble things.
How did you "check" the installed torque figure with fully cured red loctite on an installed fastener?
