stangman638
I kinda agree with that statement in general, but you just never know.It seems like half the members on here with a new 2018 have the same ticking issue. That many engines can't be bad.
This is the main reason I'm not too concerned with the BBQ tick. If I beat on the car for a bit and get it nice and hot, I can't replicate the tick until I either drive long enough for it to cool down a bit or I shut it off for a while. I still wish I knew what exactly it was and because it's somewhat embarrassing to tick my way through the neighborhood or a parking lot.Keep in mind, that smooth running engine after running it hard last night, was just a minute or so when I got home. Who knows if that will last. The bloody tick may come back today for all I know.
You have a 2018, so what you describe sounds like the 2000 RPM rattle instead of the BBQ tick.OK, today the tick is back, as usual. However, I did notice something different when I got home from work today.
At idle in the garage, there is no tick anymore. However, when I rev up to about 1,200rpm, it starts to become intermittent. Then, around 2,000rpm it becomes constant with the engine rpm, and the tick stays there as rpm continues to increase all the way up to 3,000rpm. Beyond that the tick is there, but hard to hear from engine exhaust, etc, but does not go away.
UPDATE: 1 hr later, I thought, "Gee, I wonder what it would sound like if I went out and ran in the engine a bit? Can't hurt right?" Well, I decided to drive down the road past a local airport which is a nice 2 mile stretch. I put it in 3rd gear and ran it up to 3,500rpm for the whole distance down the road and back (~50mph). I just held it there at the higher rpm than I'm used to cruising at down the highway (which is ~1,800 at 70mph). After running it at 3,500rpm for a good 10 minutes back and forth up and down the road, I left the oil temp gauge on the display, and it normally runs just below halfway, and during this run it went just above the half way mark. I pulled back into my garage, let it idle and did some minor revving.
The tick was NOTICEABLY quieter. In fact, almost GONE. I can still hear a teeny little bit, but I was quite surprised.
I'm going to do this a few more times, and see what effect it has.
Yea has been at dealer almost a month waiting for Ford to decide what to do. Dealership doesn't deny there is something, just need guidance from ford.Ouch! That is loud! There is no way a dealer could possibly claim that is normal, no matter what the cause is.
Could be, I think Ford knows what it is, curious to as why they have not fixed or released anything about it?I'm really starting to think the intermittent BBQ tick is just the early stages of a swiped journal bearing that eventually turns into a full blown rod knock.
And they keep on building them....Could be, I think Ford knows what it is, curious to as why they have not fixed or released anything about it?
I still suspect excessive rod side clearance. An additive like Cara Tech or Tribo Tex will help decrease friction and also may help "cushion" parts that impact each other.How does adding Ceratech, TriboTex, and simply running the car hard seem to eliminate the BBQ Tick (not knock or piston slap)? TriboTex eliminated my intermittent BBQ Tick. Did it repair my engine or alter the way the oil flowed, like Ceratec and runing the car hard? Is the real BBQ Tick sound from all makes of cars coming from loose tolerances or is it something else? See post #101. https://www.mustang6g.com/forums/threads/bbq-tick-solved.111085/page-6
Both hBN and MSH DLC coatings form a tribofilm that is up to several hundred microns thick. So it can reduce clearances TO A DEGREE where excessive. This may be just enough to keep oil pressure up a tad higher at low RPM or as you mentioned "cushion" the impact. The films are also self-repairing, so they will build back up if damaged due to extreme pressures exceeding their load bearing capabilities.I still suspect excessive rod side clearance. An additive like Cara Tech or Tribo Tex will help decrease friction and also may help "cushion" parts that impact each other.
https://www.mustang6g.com/forums/threads/how-excessive-is-this-rod.108361/
Update after dealer having car for a month Ford has authorized new long block for my car. Another couple weeks without it at best before getting back.Ouch! That is loud! There is no way a dealer could possibly claim that is normal, no matter what the cause is.
That's good to hear. It seems to me that if one has a very mild form of the tick there seems to be no functional issues. However it does seem there are a few cases with severe ticking where short blocks were dropped in on Ford's dime and at this point if you have a loud tick they just do it now. I agree with GT Pony that they must know the cause at this point and in severe cases it's justification for a replacement.Update after dealer having car for a month Ford has authorized new long block for my car. Another couple weeks without it at best before getting back.
Yea, noise on mine started pretty early on. Had dealership listen and both agreed that we should wait a bit to see where is goes. Within a month noise was just getting worse and for intermittent to all the time hot or cold. Dealership has been great pushing back with Ford on their suggested fixes (top end 1st then HP fuel pump) Neither were problem. Biggest disappointment during this whole thing is Ford reacting so slowly with everything. Dealer asked multiple times for a tech to come listen to get issue identified quickly and they never did. Only thing dealer got from Ford tech was a phone call. Asked Ford regional customer why it took so long to get the dealership support on this and they had no answer.That's good to hear. It seems to me that if one has a very mild form of the tick there seems to be no functional issues. However it does seem there are a few cases with severe ticking where short blocks were dropped in on Ford's dime and at this point if you have a loud tick they just do it now. I agree with GT Pony that they must know the cause at this point and in severe cases it's justification for a replacement.
