Battery Terminal connections
Rapid Red
Woodstock GA
Greg
Quick question for anyone using the CTEK MXS 5.0. Does your charger have a slight buzz to it when connected?
It’s not very noticeable but in total silence you can definitely hear it humming/buzzing. Just wondering if I should return & exchange before it’s too late.
My smart little ā€˜Battery Tender Junior’ that I’ve used for years is totally silent. I moved that to another vehicle and thought I’d try out this new CTEK.
Thank you for any feedback.
Have one never noticed any hum/buzz, I 'd probably return it, solid state should not buzz
Goose17
DFW
Tim
Many Mustangs (collector)
FYI, I permanently installed a tender lead many months ago and have used it every time the car is parked. I went the easy route and hooked it up directly to the battery. There have been zero issues... works great, lasts a long time. So what if it takes the computer time to see the new charge. The car is sitting/charging for awhile anyway.
Juantrickpony
Ohio
15GTPP
John: My hearing isn't what it once was but my garage is quiet and I'm pretty sure I would have heard the buzzing if it was occurring so I'll have to go with, my CTEK box is silent.
Have one never noticed any hum/buzz, I 'd probable return it, solid state should not buzz
Thank you. That was my feelings too. This ones getting returned just to be safe. :beer:
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
I went with a 1.5 Amp tender to be safe, wonder if I should change it to this (4 amp).
FASTCARS
Ohio
RL
F150, Wrangler, Pilot & 2021 GT500
Did you just cut off the alligator clips and then wire it directly to the terminals?
Juantrickpony
Ohio
15GTPP
Most chargers include the tail/whip to connect directly like that. They were included with my CTEK MXS 5.0 and they’re an optional accessory for Battery Tender. F those alligator clips unless the battery is out of the car.
Goose17
DFW
Tim
Iā€˜ve watched many of your YT videos. You sir have an amazing collection and garage! :clap:
Thank you very kindly! I have tenders on the cars as well as the boat, PWC and lawnmower. After many failed batteries, I finally wised-up!
As mentioned above, the tenders that I bought have a connecting plug with two end leads for options. One has the spring clips and the other has posts holes for bolts. It allows me to leave the leads in place as well as the battery cover.
gfcobra04
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
I never thought about the lawnmower until last spring. I went to mow the yard and the battery was dead. I ended up doing the same thing and purchased a tender for the mower.
RapidResponder
Seattle, WA
Ron
2021 GT500 CFTP, 2022 Shelby SSS, 2023 Raptor R
No buzz here. Just just stare at the pretty lights on the CTEK... :clap:
FreePenguin
Ohio
Donald
17 mustang
Some just buzz. I assure you I’ve had a dozen bt jr
Some buzz some dont. Must be just electronic frequency being emitted
I’m sure it’s fine
Juantrickpony
Ohio
15GTPP
I’m sure it’s fine
True, maybe it’s okay. Being brand new I’d rather play it safe and try a new one before it possibly gets worse. The replacement is already on its way. And yes, never had issues with Battery Tender. I just had to come across this damn thread and see these CTekā€˜s with all these lights and it even said ā€˜5.0’. I’m a sucker for marketing.
AngelDeath
AngelDeath
CH, New Jersey
I have 11 of the ones I pictured above. They work great... no complaints.
Just bit the bullet and got it from Bestbuy for $39.00 Going to switch it out, Thanks for posting Tim, much appreciated.
