UPR Drain Plug Leaking?
ChitownStang
ChitownStang
Chicago, North Shore
2021 Mach 1
If I recall, you have a set of ramps? If so, get the front end up on ramps and see if you get any oil runoff. If there’s anything still sitting in the belly pan, it will run off when you get the car on an incline. Since the leaking only happens when you drive, my guess is there’s still some oil hanging around from when it spilled and driving around gets the residual moving around . As others have said, it can hang around for what seems like forever.
Hey Mark, Unfortunately my rhino race ramps don;t work for the front of the Mach 1, worked great on my 15GT but the front spoiler on the Mach hits. So I lift on pinch weld and put stand under K-member then do the same on other side. Pain in ass compared to ramps!
I like your idea, I'm going to put it on stands this afternoon and see what happens overnight.
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Bummer that your Rhino Ramps don’t work the for Mach. If you want a nice set of ramps that will work with the front of the Mach, these are fantastic. I believe a few other Mach owners have these and my brother in law is able to use mine on his C8
https://www.raceramps.com/ramps/race/p/rr-xt/
ChitownStang
ChitownStang
2021 Mach 1
Funny, I was just looking at them online.
Wonder if anyone sells than locally
MAGS1
Mark
2022 Mustang GT
I’ve not seen them locally. JEGS and Summit I think both sell them as well but I believe they’re just drop shipped from Race Ramps.
Mach1Mike
Palm Beach Florida
Mustang Mach 1
So I did an oil change last weekend on my 21 Mach 1, its my 6th one and I do them all laying on my garage floor.
This time I noticed a slight leak on my garage floor every time I go for a drive. I clean it up and find another one on next drive. (doesn't leak unless I go for drive.) I Spilt a lot of oil when removing filter so I thought that may be it trickling it's way out but now I don't think so. I lifted the car up again and looked by the filter, no leak. Seems to be dripping off the edge of the plastic skid plate which is directly under the oil pan plug. See Pic. No drip from plug but it's on plastic. Is it possible the UPR drain plug O-ring is bad or something and slight amount of oil is coming out after pressure builds up from a drive. I've had this plug in since my first oil change. I'm at the point where I'm just going to go to my dealer and grab the factory one and dump all the 10 quartz into a very cleaned oil pan and then refill with same oil but what a pain in the ass!
Anyone experience this with a Bad plug?
I would read my upr writeup
https://www.mustang6g.com/forums/threads/oil-drain-plug.174136/post-3527240
switched back to yellow plug UPR plug no bueno.
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
22 Mach1 N0426, 22 Bronco Wildtrak 2dr, 92 Yota 4x
Not being someone to spend $50 on a drain plug I don't have first hand experience.
I do have a few thoughts.
1, I'd consider replacing the o-rings to see if that fixed it.
2, I thought those things have a lifetime warranty? Perhaps call them before doing anything else.
3, I've only ever used one of the "quick change/drain" type things that came on a truck I bought. It never saved me any time or mess compared to a normal drain plug. And I was always worried it would fail...
Pricey, but having that magnet is very important. You chimed without having any experience? My apologies OP… I haven’t had any issues with my UMR plug. Have you tried going back to the stock plug to see if it leaks? Got a shop vac? Dont even need to drain the oil to swap plugs…
ORRadtech
Atlanta, Georgia
There's no need for you to apologize for me.
I said up front I had no experience with that particular plug but suggested the o-rings be replaced. Guess what, if you'd have read the whole post you would know that after checking with the company the OP did, in fact, order o-rings. Experience or not, I would call that helpful. Also, if you had read the whole thread you would know another member had recommended that vacuum hack a couple of pages ago.
Garfy
Utah
Gary
2020 Mustang GT, 2012 Honda Fit Sport
Yes. I've never sucked up oil. It's just pulling air through the drain.
Sorry about the o rings. I bet you can find some at the local hardware store though. I would probably hassle UPR about it considering mine has never leaked.
Just have to be sure the o-rings are neoprene as they're oil-resistant; plain rubber ones aren't.
kellyreno
S.C.
Dal
2021 Mach 1
Don't drain your oil! You can thank me in advance for this awesome tip, which I have used to swap my drain plug when I got my UPR plug.
Your welcome! I also use it to check if any metal makes it to the magnet mid oil change, after events.
Also, when I spilled oil from my filter (I have since got a filter drain kit from another member on here which prevents spilling all over the top side of the cover), it leaked initially right after the oil change, than again after driving the car for a while. It took two oil changes for the leaking to totally stop. I guess I got a lot of oil up in that pan. I still would never go back to stock.
Good luck!
Mine leaked to my garage floor for 3 days, then once a week after the dealer did my 1st oil change. Spilled a lot in my belly pan I suppose.
JBPLAY3R
Western Australia
James
I know this thread is nearly 2 years old now BUT i also have a UPR twin oring sump plug that leaked, what i did (which seems to be holding up just fine) is remove the 2 x orings and wrapped some thread tape nice and tightly around the section where the orings go then refitted the orings and refitted back to the sump, is alot tighter fit now and so far has done the job, no leaks🤟🤟🤟🤟
Skye
≈39N
"Skye" Mach1 N2144
I'm glad things worked out for you and wish you the best, but I'd look to replace the rings the next time the plug is removed.
- Teflon tape can sometimes split, becoming "stringy" and breaking apart. If part of a threaded assembly and outside the environment that is the inside of an oil pan, great. If exposed to it, I'd be concerned about how it will react over time
- It reads like the root cause to the problem and others is the O-rings shrink over time, from exposure to heat cycles, oil and various contaminants. That's not a surprise. Or a flaw of the design. It is what it is
In August of 2024, I contacted UPR and asked about a replacement schedule, how often we should replace the o-rings. The following is their response:
"We recommend clean, inspect, and replace as needed. We do offer spare O rings of the correct size and material on our website.
https://www.uprproducts.com/upr-oil-drain-plug-replacement-o-rings/ "
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
All this work when the OEM plugs work great and are on millions of F150's. Aftermarket plugs have a higher failure rate.
WItoTX
Houston
Kyle
'17 GT350
Because the stock plug has no magnet. And these motors like to shed steel.
FWIW, my stock plug leaked, and as long as I swapped orings every once and a while on my UPR plug, it never leaked. And I could wire it so I never had to worry about it backing out. I think Ford recommends replacing the oil plug every oil change.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Get one of these: https://www.femco.com/product/ford-oil-plug-set/
After the first Exxon Valdez-level disaster changing oil on my then new '19 F150, I installed the fancy Ronin plug. Worked great for several years, but it didn't have lock tabs like the yellow factory plug and I was paranoid about temperature differentials of the pan and aluminum plug.
I then went to the one linked above, which has lock tabs. Controllable oil flow when doing a change, what a concept.
DougS550
Fishers, Indiana
Doug
For me, I have tried the Ronin, UPRs (2 different one), they all seeped. I just put the OEM YELL plug in last winter and now: Zero Seeps/leaks. BUT< I know there is a mess coming when I change my oil again in March.
