Stereo Information (Wiring, Upgrades, etc...)
bless0
Tampa
2018 Ingot Silver GT/PP/AE/MR Recaros
Are the speakers 2 Ohm or 4 Ohm ?
Lightning Struck
Waupun WI
2018 Kona Blue PP2
Would a 3.5" midrange with a mounting depth of 1.8" fit? I could make a spacer if required, and there's enough room between the door panel and the driver...
mumbles
ATL
Eric
'16 GT Prem OW
There seems to be different ratings used... some have 2ohm drivers (like me in my 16 PP Prem) and others have 4ohm. Your best bet would be to verify what your car came with.
mumbles
ATL
Eric
'16 GT Prem OW
ForTehNguyen used some Dayton RS100's which are 1.8" deep in this thread;
https://www.mustang6g.com/forums/showthread.php?t=29714&highlight=dayton
Not sure if he used a spacer or not, you might IM him.
My speakers were 1.2", but I used a razor blade and trimmed the plastic ribs on the inside of the door panel to give the speaker surround some clearance.
schenoy1
Waxhaw (Charlotte area)
Mustang GT 2015. Ruby Red
Does anyone know (for sure) the Gauge size of the stock wires to the door and rear speakers, 14 or 16 Gauge? Thx.
Diocletian
Orlando, Florida
2018 Orange Fury Mustang GT Premium A10 w/ PP1.
Both my 3.5" door speakers in my new 2018 GT premium(401a non-shaker) are already blown. Instead of replacing them with crappy OEM I figured now would be a good time to upgrade them. Any recommendations for direct upgrades(no modding needed) for them?
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Does anyone know how to release the pins on the amplifier brown connector, Molex# C2385B ?
I want to release pin 2, green wire, to the center speaker, and then be able to reconnect at car trade-in.
randy_tho
Tennessee
Does anyone know where and how the 6.5s and the tweeter wiring separates on a base car? I can't find anything except that that they are on same line and the tweeters have the blocker on the back. I'm hoping it is harnessed in the kickpanel.
NotMarc
Earth
22 Mach 1
I would jump on partsexpress.com and try to match resistance and dimensions. My car has about 1k miles on it and I think I already hear some distortion from mine on the passenger side so it may be a sign to start preparing for a full build!
With that being said, I want to start my build and had a quick question.
When powering my DSP should I:
(a) Tap the power and grounds from one of my amp's 8 ga wires (not sure of how to do this cleanly and safely or
(b) try getting power and ground near the fuse box and keep the aftermarket DSP in the stock location? I want to do whatever has the least change of introducing a ground loop or whine in the system.
michail71
2018 GT 401a A10
How does one verify which speakers? The parts diagrams don't seem to indicate any differences outside of convertible/coup and branded/unbranded.
mumbles
ATL
Eric
'16 GT Prem OW
Not sure about the "no modding" part, but I've heard good things about the Infinity Kappa Perfect 300m and the Audiofrog GS40 could be a good choice as well.
mumbles
ATL
Eric
'16 GT Prem OW
If you used a distribution block to provide power to your amps, you could just add a smaller guage wire to that for you DSP, they typically don't use much power.
mumbles
ATL
Eric
'16 GT Prem OW
If you are just trying to disable the center channel, it might be easier to disconnect at the speaker itself?
mumbles
ATL
Eric
'16 GT Prem OW
You'd have to physically remove the speakers and check the labels...
NotMarc
Earth
22 Mach 1
Okay. Just to be clear. my setup will be like the picture below. Are you saying to just add an extra small wire in the compression fittings of A and B for power and ground to the DSP? Because I won't have any "spare" outputs.
