Questions about Kooks install.
WCRookie99
Illinois
G
2021 Mach 1, 2007 FR500C, 2022 LH5
I tried pushing them up with the jack but it's as far as they go. The H pipe is nice & flush as well as the cat pipes. But past that they get lower. When I raise them with the jack, they hit the sub frame by the differential. As they stand now, they are about .25" from hitting the frame.
Could be angle, or just a little low but if it fits in the rear probably ok.
DougS550
Fishers, Indiana
Doug
I didn't know they had such item. Will look into it. I was just thinking getting a tune would fix the CEL. Being that I didn't delete the cats, they should just be able to tune for the larger exhaust flow I assume.
I was told by a Tuner they do work, but until someone says, Yes I had a cel light, then installed the adapter and the light went out, I won't believe until then. Call me sceptical.
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
This is how they sit now that I lowered it on the ground. Honestly car is not as loud as I expected it to be. Sounds more deep, but not as loud. Taking a lot longer for the oil to burn off than the 1st time I did headers. Thanks for the pics. I do see how the rear pipes start to come down some after the H pipe
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
I'm gonna have to look into this. Might try them just to avoid the tune. But the thought of raising it all back up now makes me just say that he'll with it lol
daSNAK3
Cary, IL
Jake
2021 GT
It'll work.. I used spark plug non foulers as spacers on my catless Cobra to get rid of the CEL and pass emissions.
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
I'll have to look into it. If it makes the O2 sensor stick out any it might not work due to how close they already are to the wall. When I lift the car to retorque I'll take a good pic of the O2 sensor. Don't have to worry about emissions here in KS, was only considering to avoid tuning yet.
DougS550
Fishers, Indiana
Doug
Thank you for your feedback. Most appreciated.
Prodigal
OKC
2021 Mach 1
With the Big Daddies fixes, which of the 3 products are suggested to avoid the CeL? The mini cat says it’s for cat less applications while the angled and straight CEL fix just move the sensor out of the exhaust flow.
my Looks are catted but what I’m reading in the thread is that even with green cats I’m likely still to get a CEL. Correct?
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
If it doesn't start snowing by the time I get off work, I'll try & put on a few miles to see if I get the CEL
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
Did you get your set up all installed? There is not much room to add a spacer to the O2 sensor
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
Can anyone tell me what that sound at the 1st start might be? Don't sound good
Prodigal
OKC
2021 Mach 1
Nope. I have the LTH and h pipe but my car is in hibernation till spring. I’m just trying to accumulate all the go fast goodies I need for 1 trip to the speed shop to have it all installed at the same time once the weather warms.
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
Oh I see.
Cordero1
Cordero1
Kansas
Vic
2021 Mustang
The coyote engine with aftermarket exhaust. It would be even more violent with an x-pipe.
I was honestly expecting it to be much louder. But still really like the sound. Was just curious that sound was at first start.
