Pursue a buyback?
ShelbyEnthusiast
Illinois
Shawn
2014 Honda Accord "sport"
Backstory: I purchased a used 2020 GT350 @ 4400 miles in Oct 2021. Since then the compressor has gone bad, the long block has been replaced, and the compressor has gone bad again.
1st compressor: early 2022
Catastrophic engine failure(bent pistons): end of 2022
2nd compressor: early 2023 and its worse right now(sounds like a supercharger + my compressor is coughing blood everytime i turn the AC on). issue started the day i got the car back after long block replacement
The remedy from Ford for the long block replacement, and for context I pushed the Ford Customer service representative hard for compensation. All I got was premium Ford care till the end of this year.
I'm pissed. I've completely lost faith in this vehicle.
There's other issues too like in reverse when I push the clutch in and out it sounds like the transmission is literally coming loose. Wheel ticking, brake squeal(normal i hear), clunking nose when shifting into first gear(again normal i hear), rod knocking at cold temps(again normal i hear), whining between 1k-3k RPM's(without AC turned on). So many smaller issues...
I'm not sure exactly what I can do here...if there's anything I could do even
matthewr87
2018 GT350
Sorry to hear about your troubles. Looks like you've had a tough go. The engine failure is just bad luck; although there have been a few reports here of 2019+ engines just going bust, it seems rare. But unfortunately the AC compressors go bad on these cars with regularity. The other issues you describe are also mostly "normal" as you say. My car has most of them (other than the reverse issue you describe). I just take the car for what it is and enjoy it. It certainly is not the most refined car. I understand however how your experience has colored your view of the vehicle.
pilotgore
US
A bunch
Unfortunately I think buyback is only really an option if your states lemon law policies apply, usually one year. At least that’s the story I got from ford when I asked about a buyback.
My advice, get some local ford dealers to make an offer a the car. I got offers from 7 ford dealers, carmax and carvana before eventually selling it to one of my local ford dealers. I ended up selling for $8k more than what I bought it for new, and this was right after the long block and transmission had been replaced. Once you lose faith in the car, it’s so hard to have fun in it as you’re always wondering what’s next to break. Sometimes a clean break is the only way to maintain sanity.
sublime1996525
SL,UT
2017 Race Red GT350
I don't think a buyback will happen. There has to be a long trail of unfixable issues. The wheel clunking and loose transmission should be looked at if you're concerned. The other issues you're probably hearing is piston slap, but can be looked at, and brake squeal is common with performance cars.
WItoTX
Houston
Kyle
'17 GT350
I totally get where you are coming from. It sounds like it's stressing you out. Since that is the case, I would get the compressor replaced, check lug nuts (Known to make noises if not at 150 ft-lbs), and if it still bugs you, maybe it is time to sell.
Good luck! I personally think having the replacement motor is a huge plus when it comes to sales time.
Kachow
Georgia
2017 GT350
Agree with Pilotgore and Wilto. Get the AC fixed again - then trade or sell in to a dealer. If you're looking for something that you can beat on day in day out without all the little niggles of the 350 (I have many of the same issues), I would suggest a ZL1 1LE or SS1LE. Not as exciting motor wise but on par performance and never had an issue with mine when I owned. (Nor others I tracked with)
460Fred
Wyoming
Fred
‘19 GT350 (sold)
So let me get this straight.
Your first thread (1 1/2 years ago) was asking what to look for when buying a GT350. You mentioned a ‘19 with 4K miles and cooked tires.
The following month you picked up the car you are talking about here.
Man OP bad luck has followed you for sure. I’d take pilotgores advise and get an offer from a few dealerships.
Now you’re going to think I’m nuts. I‘d buy another one.
Overwhelming majority are great cars. The fun to dollar ratio is undeniable.
04DarkShadowGT
Fort Wayne, IN
2020 Mustang GT
Since the car was bought used there is no buyback or lemon laws in any state that I am aware of. No dealer is going to take a return on a car that was sold nearly 2 years ago.
My advice would be to get the car repaired again and just sell it.
ZXMustang
US
2025 Mustang GT
Lemon law is only for the original owner. Does not apply for second owners and beyond.
AZlb5.0
Arizona
Carlos
18 GT Premium
Most buy backs occur with the original purchaser because of state lemon laws. Since you’re purchaser number 2 and these issues are well know and Ford has done what they can to fix them it’s highly unlikely that they will purchase the car back. The only way I would foresee a buy back would be that your engine keeps failing they keep replacing and there seems to be no real fix to that particular problem. Everything else is documented as normal wear and tear for these vehicles so I am sure that you’re stuck with it
stanglife
Jeff
1993 Coyote Coupe
I believe there is a TSB for pinion nut on the trans which could explain some of the clunking you speak of. I have zero clunking at all. Maybe a premature to diagnose what you hear as a rod knock - it's typically piston slap, as others have noted and it "usually" 99% goes away after the pistons get some heat in them. I think the issues you describe are fixable. It sounds horrible when you list them out all together but if you just get them tackled one at a time, you can go on enjoying the car with only slightly higher than average concern of future failure :)
ZXMustang
US
2025 Mustang GT
Is There a Lemon Law for Used Cars in Illinois?
Yes, consumers in Illinois may use the federal Magnuson-Moss Warranty Act to provide them with relief for the purchase of any used car, truck, SUV, or other consumer product. This federal Lemon Law makes no distinction between new and used vehicles. If the vehicle meets the definition of a lemon, it’s covered.
This holds true even though the State Lemon Law in Illinois applies only to new vehicles. As long as you (or a previous owner) report a defect while the vehicle is under warranty, the federal Lemon Law holds the manufacturer responsible for the repairs. And if the manufacturer fails to repair the defects after a reasonable number of attempts, you can seek compensation through the courts.
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
Give Carvana or Carmax a call, dump it on them.
f00man
West Coast
Aaron
2022 Mustang M1 HP
Yikes. The lack of reliability would have be stressed out as well. I hope you can successfully pursue the Lemon Law for your GT350.
DCShelby
DC
Robert
I’ve never heard of a lemon law in any state for a used vehicle. I’d turn off the AC, drive it to Carmax and let them have it. I suppose if the OP owes more on it than he can get, that’s another problem.
