Manuel to auto swap?
sachmo133
Lebanon, TN
2021 Mach 1
This is just for my curiousity, is going from a manual to auto swap in a 2021 Mach 1 doable? I’m getting older an have hip/back/leg issues and makes it harder and harder to drive the manual. So I was wondering if this is something to consider and how much would it cost.
I’m sure in the end it might be better and cheaper to trade in the manual for the auto but I have my car set up the way I like it Suspension wise.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Sycostang67
Kuna, ID
1967 Mustang, 2015 Mustang, 2001 Ram, 2012 Wrangle
I’ve done several auto to manual swaps in the past, couldn’t imagine doing it on something as electronically interconnected as these cars. I’m sure it could be done, but it wouldn’t be as simple as a trans swap and pedal cage.
HKusp
Hampton, Md.
Jason
Who's Manuel, and why do you what to swap him?:crackup:
ORRadtech
Atlanta, Georgia
Agreed. Probably need an ECM, a BCM, a TCM, wiring harness - engine and trans if they're separate, shifter, maybe a center console, driveshaft maybe, different sensors, a steering wheel and the wiring harness for that, obviously a flex plate and torque converter, maybe a different starter and????
And then there's the programming...
Yeah, probably, easier and cheaper to just buy an automatic car and redo the suspension again.
1MeanZ
Indiana
Jeremy
2016 Mustang GT PP M6 1986 Camaro IROC-Z
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
Sell the car and buy a manual…
By the time you invest in a donor vehicle (which is THE best way to do it), you’d be too deep in the $$$ to even recoup anything if selling later down the road…
Swapping transmissions and pedal boxes isn’t like it was 15-20 years ago - there’s A LOT of modules, programming, wiring harnesses and electronics involved. It’s not a 1 day event. It’s very costly. Can it be done? Sure, but it’s just not worth it.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Like others have said. Get it back to stock and sell the car. When you get the auto put the suspension mods back on it.
sachmo133
sachmo133
Lebanon, TN
2021 Mach 1
Yeah, I think I just needed to ask and get it out of my head. Makes no sense to even consider it.
