Rear gear swap to 4.56 and Auto Rev Match on '22 GT PP
RonsterGT
Canada 🇨🇦
Ron
‘22 5.0 GT/‘16 F150 XLT/‘21 Explorer Platinum
I'm considering a differential gear change to 4.56 from the stock 3.73.
As most of us know, the '18+ M6 D4 has different ratios than the '15-'17 M6 D4.
'19+ M6 D4 incorporates Auto Rev Match (ARM).
I owned a '16 M6 and the difference in the D4 gearing between '15-17 and '18-'22 is rather noticeable.
I have scoured this forum and discovered I can swap gears and likely won't need a "tune", since others have done this successfully.
However, their cars did not have Auto Rev Match (ARM).
My question is:
"Will I need to tune for the new gear ratio in order to maintain ARM functionality, or will the computer(s) involved self-adjust?"
Thanks for your insight.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It will not self adjust to 4.56. You will need a tune so call some tuners first.
RonsterGT
RonsterGT
Canada 🇨🇦
Ron
Thanks for your reply.
If I get a hand held tuner that allows for 4.56, would that work? No full tune download, simply gear ratio change is all I'm considering.
K4fxd
NKY
Wengerd seems to be very customer oriented. I'd contact them and ask if they would give you a gear tune only.
@Wengerd Performance
Wengerd Performance
Gold Sponsor
Paris, Tn
wengerdperformance.com
Derel
18 GT Whipple 15 Mustang GT TT 18 F150 VMP ODIN
Correct you will need a tune as the BCM will not self adjust for that ratio. They self learn 3.15-3.77
