Manuel swap s550 2015
Esco5.0
Franklinton Louisiana
Jace
2015 Ford Mustang Gt
Anybody know the cost and everything i would need to Manuel swap a 2015 gt, don’t bother saying it’s expensive just wanna know around what price and everything i might need
junits15
MA
Justin
2019 Mustang GT
Is there a reason you don’t want to just sell it and buy a manual?
KingKona
Virginia
Shlomo
2019 GT
Who ya gonna swap him for?
Esco5.0
Jace
going for the budget so if i can an mt-82 but thought about a used tremec if i could get my hands on one
KingKona
Virginia
Shlomo
2019 GT
How much are you imagining this will cost you? $5K? More?? Maybe $7K or $8K??
You need the trans, flywheel, clutch, pressure plate, throw out bearing, pedal assembly, brake master cylinder, hydraulic hoses, shifter assembly, console and various trim pieces......and then to have that all installed.
Yeah, probably over $8K. The trans alone is $4K.
Genxer
2015 Mustang GT / Perf pack / DIB
Does one have to change the ECU when going back and forth between auto and manual?
1MeanZ
Indiana
Jeremy
2016 Mustang GT PP M6 1986 Camaro IROC-Z
WItoTX
Houston
Kyle
'17 GT350
I would pull this off the internet so my bank doesn't find out. Banks have been known to call the note when they find out the owner has modified the car to make it less sell-able.
I'd bet Google would get you some answers.
Scootsmcgreggor
CA
2016 Ecoboost turned GT
dont forget the car will freak out when there's no auto trans any longer. Will need to get that addressed in various modules in the car, PCM, BCM, and IPC, probably more.
shogun32
Northern VA
if you have 8-10 grand to blow, you have the money to pay it off and get a manual that Manuel hasn't driven.
Oh and the rear-diff coupler for AT/MT is different. I don't know if that's the extent of it, but you may need a different drive shaft (length). Then there is the craptastic diff ratios that may well ruin your 6MT experience.
Doesn't the '15 have paddles? Just put the trans in 'S' mode and force yourself to use the paddles for each gear change.
It's free. :)
Esco5.0
Jace
i was gonna try to do as much of it as i could myself
Esco5.0
Jace
It's free. :)
who said i modified it?
ORRadtech
Atlanta, Georgia
A manual transmission swap is kinda the definition of modifying it...
And a mod that will destroy the value of the car.
