Lowering Spring Install Cost Estimate
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
do not buy them unless you're building a race car.
Ok., so with the springs and camber plates I don't need the bumpstops?
shogun32
Northern VA
You need 'something' as a bump stop to decelerate suspension bits moving out of control and about to crash metal on metal.
Get the Eibach ones and cut them down.
LethalBlake
Palm Beach
www.lethalperformance.com
Blake
2017 Ford F150
$300-500 depending on the type of shop and location. I would also highly recommend getting an alignment as well which will typically add about $100-150 to the price.
Matthewstorm
NC
Matthew
Isn't there anything available that's just plug n play?
shogun32
Northern VA
yup. Don't lower your car. Done.
The Eibach (Ford too?) can be cut with a hobby knife. There are even convenient grooves you can follow.
m3incorp
Georgia/Colorado
James
Matthewstorm
NC
Matthew
m3incorp
Georgia/Colorado
James
They are already pre-cut. This is from my order.
555 4453
Steeda Mustang Pre-cut Bumpstop / Jounce Bumper Kit (2015-2020)
$53.96
$53.96
Steeda springs with bumpstops?
shadowblack_badger
shadowblack_badger
Georgia
Brandon
2017 Mustang GT
you want to cut an equivalent amount from bump stops that you're dropping the car as measured at the hub-cap, modulo motion-ratio.
Up front it's 1:1 (or close enough) so if you lower by 1" chop the stops by 1". The rear is 0.7 so for 1" drop, cut off 0.7^2 or 0.5".
It's always better to have bump-stops that are too short than too long.
Simply put and thank you!!
m3incorp
Georgia/Colorado
James
shadowblack_badger
shadowblack_badger
Georgia
Brandon
2017 Mustang GT
Update: got a quote for $450.00 for install and alignment. I trust the shop and have done business in the past with the guy. Based off everyone’s response to this post and today’s quote, I feel this is going to be the average.
Matthewstorm
NC
Matthew
What exactly are you installing?
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
