Lowering spring install help
Furious_S550
youtu.be
2016 Ford Mustang GT Premium PP
I'm in the middle of the install on the front strut. Can't get those two bolts out. I've tapped, I have hammered and I banged. Is there an easier way? They ain't budging.
ColdShotxx
Idaho
2021 Mustang GT A10 300A Base
I put a couple hours just on this step as well. I had go buy a sledge hammer to wack them out.
The other step that go me was later on once strut assembly out, removing the top strut mount nut. I found a really easy solve for this, a small 1/4 socket, with a 1/4 extension nested in a 1/2 socket for the outside nut (the outside socket having aplace to grip with wrench)
Furious_S550
youtu.be
Appreciate it. The strut itself is easy. Just these bolts.
scott_0
Oxford, Pennsylvania
some have proven to be pressed in tighter than others, just keep hammering man
blown302
ct
1987 mustang gt/2004 svt cobra/2016 GT PP
try putting a jack under the strut to to take some of the load off the bolts.
Doctor Fishtail
Mexico
Mustang GT
The first time these bolts come out it is like breaking in a virgin. LOL. Work work work. I banged so hard and for so long.........LOL. A 4lb. baby sledge hammer is a must.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
Loosely thread the bolt and tap it. Mine came right out
Horde5.0
SoCal
The Warchief
2015 Mustang GT
Putting both nuts on the end of one bolt made a difference for me. The bolts hammered out much easier when I did this.
JAS550
Saint Mary's, GA
2016 GT black accent package
I had the same issue , took me about two hours to get just the drivers side bolts out. Ended up using a lubricating spray and they came out in about 5 min.
Furious_S550
youtu.be
I appreciate all the support. I finally got it out. Needed a bigger hammer.
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
For anyone else who reads this thread. I eventually turned the wheel so the end I needed to band was facing out a bit. I was able to get much better leverage when whacking the bolts. could even stand while doing it :).
whack - whack - whack ---houston we got movement lol
Furious_S550
youtu.be
So I needed to use a 20 oz hammer and by turning the wheel was able to get the angle I needed. I wish I had a sledge hammer, and tried to buy one but Walmart was sold out. I will say, get an impact gun. I caught a cramp in my forearm trying to do this install.
timd38
Hudson WI
GT/CS C6 Corvette
Air chisel with with a round tip pushes them out.
Make sure you have new bolts. They are supposed to be one time use anyway.
