ForTehNguyen
- Apr 23, 2015
- Houston, Texas
- 15 GT
yes youll need a single action clamshell type compressor for the front struts.
I didn't drop the whole subframe when I installed my springs. The rear install was cake compared to the fronts. Those strut bolts were stuck and not much swing room for the hammer.Thats cheap, sometimes they charge more as you have to drop the sub frame
I've heard everything from the rears being a pain- to the fronts being easir and vise-versa.I didn't drop the whole subframe when I installed my springs. The rear install was cake compared to the fronts. Those strut bolts were stuck and not much swing room for the hammer.
Loosen the bolts. I took out the subframe bolts on the side I was lowering. You have to completely remove the bolts to put in the bushings anyways. I installed the subframe bushing and alignment kit from steeda at the same time.I've heard everything from the rears being a pain- to the fronts being easir and vise-versa.
So you just loosened the 4 subframe bolts enough to pull the springs? On the video's l've seen they make seem like you need to really reef down on the subframe to get the springs to come out.:shrug:
Since l'm one of the lucky owners with a misaligned subframe l'll still need to at drop it to put the subframe alignment bushings in.:frusty:
For the fronts l'll use my impact gun for the splined strut bolts if they won't come out with the BFH method.
OMG!!!Almost as bad as quote for a ProCharger install I got a few months ago.
I did the bushings and cradle lockout install at the same time so I just loosened all four bolts and completely removed them on the side I was working on to get the bushings in. It's a really good idea to get at least the cradle lockout installed with the coils. For just the coils, you don't have to touch the cradle/subframe bolts.I've heard everything from the rears being a pain- to the fronts being easir and vise-versa.
loosen only one side at a time. If you havent done any rear IRS strengthening or diff bushing inserts, do this at the same time. Rears were easy, could do the rear springs and shocks in under 1.5 hours. Fronts took me 3 hoursI've heard everything from the rears being a pain- to the fronts being easir and vise-versa.
When people try to stick it to honest people, it makes me sick.. EVERY TIME A SHOP DOES THIS, WE SHOULD POST THE NAME AND ADDRESS.. They think because you are there you know nothing!Almost as bad as quote for a ProCharger install I got a few months ago.
https://www.yelp.com/biz/db-performance-engineering-whittierWhen people try to stick it to honest people, it makes me sick.. EVERY TIME A SHOP DOES THIS, WE SHOULD POST THE NAME AND ADDRESS.. They think because you are there you know nothing!
Buy a second jack and just drop the rear subframe. It's 18 bolts total you have to remove. The 2 bolts holding the brake lines, the 8 bolts on the shocks, the 4 smaller front brace bolts, and the 4 subframe bolts. I could do it by myself in about an hour.Well, shit. I've had my SP080s since Monday, sitting in the box, tried a couple of local options, first a pretty good shop, does modern and some classic work - I guess they use a service system for typical estimates, they came up with 5.5 hours, too much at their rate.
Originally, my local Ford dealer said about 4 hours, then I called back to schedule and it was up to 5 hours @ $115/hr, too much.
I posted in the local Florida section, hoping someone would know a shop, even a person willing to do it, no luck so far.
After reading through this, I'm super tempted just to do it myself, I'm a decent wrench turner, I'd need a spring compressor though that seems cheap. I have tools, some rino ramps, stands, a good 2.5 ton floor jack.
I don't daily drive the car, but I might have a sudden situation where I need it (just local use within 10 miles or so) ...
... I'm assuming it wouldn't be crazy to drive it with just the fronts or just the rears done, figured I'd do it over a couple of days.
