Issue at track, oil pressure
09cs
CA
2019 GT350
Was at Willow Springs today and had a great day, until my last lap of the day.
day had gone well with no issues. Hot day around 100* outside. On my last lap I was almost out of gas, gauge said 15 miles to empty, and going down the straight, and my low oil pressure light comes on. Immediately get off the gas, no smoke or oil trail coming out the back, and oil pressure gauge is bouncing (literally) between 25-50.Then all the sudden it shot back to normal range. Oil temp was around 250.
What caused this? Was it the low gas? Oil too hot?
Thanks!
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
subbed for curiosity.
Rapid Red
Woodstock GA
Greg
Did not mention oil level, if low, borderline, the pump could be sucking air. Track a car always check after an outing, and top off as needed.
"Was it the low gas? Oil too hot?"
Not likely, reads more like a capacity problem supply & demand.
Hack
Minneapolis
Mustang, Challenger
It could have been a guage issue as well, but I agree with Rapid Red that it is most likely the oil level was on the low side. Definitely with the oil being hot (and therefore less viscous) less of it will go through the pressure bypass, so the oil pump might get more oil into the top of the engine more quickly.
I'm surprised this would happen on a straight rather than in a corner, though. I wouldn't expect that at all.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
It ain't got no earl in it. No but really, what is the level? Does the car still run normally?
09cs
09cs
CA
2019 GT350
Check oil before going out, and it was fine. Car ran fine and normal on the 100 mile drive home
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Sounds like you pumped the oil out of the pan, when you let off the oil had time to drain back and all was fine. This used to happen all the time back in the day. People would put high volume pumps in engines with 5 qt sumps. Actually 4 plus a filter. You could get away with it on a 1/4 mile but any long pulls or a road track and bye bye bearings.
I don't know what oil you are using but try a thicker viscosity.
stanglife
Jeff
1993 Coyote Coupe
Did you check before you went to the event or before each run? Even cars that don't burn any oil normally, tend to eat some at a track event, so keep an eye on it each run. My wifes 01 Cobra was really bad about that.
09cs
09cs
CA
2019 GT350
should have clarified, checked before going out on that session and before each
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
I don’t think the pressure itself can change that fast, to bounce around then shoot up to normal. Perhaps check the sensor itself or the wiring from it. Can you read any codes or errors?
JAJ
Vancouver BC
2016 GT350 Track Pack
Looks like an electrical problem. There are a bunch of posts in this thread from people who don't quite grasp that a GT350 engine with the composite oil pan has an oiling system built for track work. Rather than the usual suspended steel oil pickup tube with a mushroom head on it, there's a large duct molded into the bottom of the pan that goes up to the oil pump. Between that and the baffling, it's almost impossible to have a loss of pressure because of high lateral or longitudinal G forces.
Similarly, the head and block have large enough drains that oil doesn't build up in the heads, and even when you pull over 1 lateral G for a while, the pan is large enough that it doesn't run out of oil. As I said, the Voodoo is built for this stuff.
So, if you had an adequate oil level before and after the session, and the oil temp was below about 280 degrees, then everything was fine and it probably still is. It's possible that there was something that blocked flow briefly, but usually anything that blocks flow destroys the engine in seconds and in your case, that didn't happen.
460Fred
Wyoming
Fred
‘19 GT350 (sold)
Please elaborate. Not understanding how one can have a brief obstruction. What could cause that is still there. Am I missing something.
My #10 Track Attack car had no pressure for the last couple laps. I didn’t here the warning chime because I was so focused….fastest part of the day. Once I heard it I pulled in. Watching my tape I realized the oil warning chime was going off long before I noticed it. Car felt perfect up until I noticed. After I noticed I just backed off slowly into the pits. Again, car acted fine. You would think without pressure you’d go into limp mode but it didn’t.
JAJ
Vancouver BC
...how one can have a brief obstruction. What could cause that is still there. Am I missing something...
You're not missing anything. If there's junk floating around in the engine somewhere, it'll happen again. OP needs to watch to see if it recurs.
...You would think without pressure you’d go into limp mode but it didn’t.
Oil pressure doesn't trigger limp mode for some reason that must make sense to Ford...
09cs
09cs
CA
2019 GT350
Definitely going to be watching for this again
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I’d get this oil analyzed by black stone labs or similar and see if there’s anything weird in it. It’ll help you understand if there was junk in there.
