Hood Struts
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
I've had the Steeda for about 3 years. I'm in Canada and have found that in colder weather they won't hold my hood up anymore.
But in warmer weather they work fine.
Also as a waiver I have a big fake MMD hood scoop so of course that's probably the cause. But they worked before perfectly for years.
ralph7
ralph7
Houston
2000 GMC Sierra 1500, 2019 Mustang Bullitt
noac said:
i avoid using these since they scratch the inner fenders when installed
Which "These" are you referring to?
Keeffa
australia
keith
ford mustang 2018 gt
I've avoided hood struts and am sticking with the OEM post. I've had to many hoods come down on my head when the struts decide it's to much for them.
MattMPA
SE PA
2022 GT, 2016 Interceptor Utility, 2005 Excursion
I tried installing the Redlines.....they moved around despite my best efforts. I'll stick with the prop rod too
  • Like
Reactions: NJ3
NJ3
Virginia
2015 Oxford White GT
Same here. I ended up returning them. BTW, I didn't have any issue with them on my 2015 Mustang.
noac
Tom
Mustangs
[/if h
all of them. The very nature of the install damages the paint on the inner fender and hood bracket. I know this isn’t a big deal for lots of folks, but it makes me cringe.
MattMPA
SE PA
I put a set on my '16 Ford Interceptor Utility and they are great. But, they mount differently. A friend with a '23 Mach 1 has the turning issue on his struts too with the Redline kit.
Cordero1
Kansas
Vic
2021 Mustang
I had a set of struts saved on a list for under my Xmas tree. After reading this thread I think I'll just stick to the hood prop.
DRKHORS
Mark
'18 F150, '23 Mustang GT
I've put two sets from Redline on a 2015, a set on a 2017, and a set on my 2023. Never an issue with any of those four sets. On my 2015 I was also running a heavier TruFiber fiberglass hood and the struts held without issue. At about 7 years old the original set on my 2015 got to where I would have to assist in raising the hood, but once fully raised they never let the hood fall.
Others may have other experiences, but it's always one of my first mods and I can't imagine having to work around a prop rod after having these for 8+ years.
SH!FT
CT
2020 GT premium 6MT VB
be a great idea if I had the equipment to make lol
Installing a self-tapping screw through the strut bracket and fender might be enough to make the FP struts stable.
The bottom mounting brackets are such a piss poor design. Don’t buy the FP’s.
Erieecomustang
Illinois
2016 Ecoboost Mustang
I went with the reclines. They were easy to install and held the hood just fine. I did crush the washer fluid hose. I thought it was out of the way. After that, I 3D printed a simple bracket to hold the hose out of the way. I used a 3m command strip to attach the bracket to the hood. Problem solved!
