HKusp
- Jul 22, 2021
- Hampton, Md.
- Jason
- 2018 Mustang GT
I'm going to say 870ish.
On the 110mm I think thatās gonna be a heck of a spicy tune! My guess is 770ish.I'm going to say 870ish.
You may be right. I may be overestimating the boost that the 110 pulley is capable of producing.On the 110mm I think thatās gonna be a heck of a spicy tune! My guess is 770ish.
The 110mm is rated at 10.5 psi at 7200 rpm. So reving out to 8,000 would put it at maybe 12ish?You may be right. I may be overestimating the boost that the 110 pulley is capable of producing.
12psi. I will go with 750.The 110mm is rated at 10.5 psi at 7200 rpm. So reving out to 8,000 would put it at maybe 12ish?
Iām thinking high 700s maybe 780-790 last night I ran 5.7 60-130 pretty consistently Iāll post draggys along with dyno sheet WednesdayAny expectation of what youāll put down?
Agree12psi. I will go with 750.
I'm at 13 psi A10 car. Roush 2650. I ran a 5.50 60-130 @775whp SAE Dyno jet. I'd say your right in the ball park 750-775.Iām thinking high 700s maybe 780-790 last night I ran 5.7 60-130 pretty consistently Iāll post draggys along with dyno sheet Wednesday
Definitely wouldnāt mind that at all⦠for now plenty of power to have fun and actually put the power down most of the time, mind you these draggy 60-130s were done in a 42° weather on a slight incline, with some wheel spin, so some room for improvement in that aspect . Weāll see how the car does on the dyno though. Just ordered a Fore Innovations triple pump fuel system and a 95mm pulley (14.5-15psi) and then Iāll dyno again and see the difference between the fuel systems. Tried the Sai Li route but it just seems to run out of steam pretty quick up top, but like said weāll see how she does this Wednesday⦠Iāll keep yall postedI'm at 13 psi A10 car. Roush 2650. I ran a 5.50 60-130 @775whp SAE Dyno jet. I'd say your right in the ball park 750-775.
Wow not bad at all however probably had a pretty decent fuel system⦠Iām running Sai li dual pump and high flow rails ⦠so weāll see⦠Iāll be happy with mid - high 700s until I upgrade my fuel systemLocal shop just ran a gen 3 with a G3x and G4 intercooler on a dynojet
640hp 93 120mm
704hp E85 120mm
750hp E85 115mm
793hp E85 110mm
I don't know how you get the car to hook in 42° weather. I wouldn't even try at the temp.Definitely wouldnāt mind that at all⦠for now plenty of power to have fun and actually put the power down most of the time, mind you these draggy 60-130s were done in a 42° weather on a slight incline, with some wheel spin, so some room for improvement in that aspect . Weāll see how the car does on the dyno though. Just ordered a Fore Innovations triple pump fuel system and a 95mm pulley (14.5-15psi) and then Iāll dyno again and see the difference between the fuel systems. Tried the Sai Li route but it just seems to run out of steam pretty quick up top, but like said weāll see how she does this Wednesday⦠Iāll keep yall posted
Oh man Texas (CTX) is still extremely active racing 30-55 degrees nightly ⦠just gotta roast them tires a bit⦠ran a Trackhawk on slick last night and a mkv Supra claiming 780whpā¦got them both by at least 3-4 cars so thatās why Iām even more curious as to what Iām gonna dyno at (last night was 50-55 degrees)I don't know how you get the car to hook in 42° weather. I wouldn't even try at the temp.
