Anyone using Sai Li fuel system?
TexasGT
Derek
2016 GT
Didn’t burn a pump, but did blow a fuse on one pump while doing 185+ runs
Tommy V
Brookly park Md
Tommy
Better check your wiring,u should not be blowing fuses not matter how fast you.run.Check your ground connection at the ground point and see if they get hot after about a minute or 2 of r unning,or check them with a volt meter and see if u have voltage coming through the ground,if so u need to.find a new ground.Dont just up the fuse amperage!!!!
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
[MENTION=9456]Tommy V[/MENTION] 's parts list
[MENTION=9456]Tommy V[/MENTION] How's the DIY system working..Which pumps/ Hat did you use?
Brent Davis
Northern Virginia
2018 Shadow Black Premium Mustang GT
VERY easy system to install. The only thing I don't like is the harness is too long for the S550. It seems that the wiring was designed for the S197 in the trunk fitment. Either way it went in without issues and works as advertised.
Tommy V
Brookly park Md
Tommy
Mine is still working good,gt 350 pumps.I had some grounding issues at first and that why i think i was running lean up top.I since used 8 and 10 guage wire on all the wiring and soildered all the connections.I do still have the bap hooked up but only running it at 16 volts.Car is running high 9's and well over 4k pounds.
Silver550
Cen-Cal
Richard
15" Silver Premium PP
Would this fuel system support 800 whp with id1050’s on e85? I’ve been reading around and it seems that people are starting to upgrade or move on from this kit. I was wondering why that is?
Logan@Lethal
Tampa, FL
www.lethalperformance.com
Logan
2020 GT 3.0L Whipple
It is a great kit for the price.
The twin GT350 pumps in a stock GT350 hat is the restriction, so people swap it out for a full kit.
On a '15, you can run this kit or our level 1.
Let me know if you need any help or want pricing while sales are active.
Gregory347
LI, NY
Greg
2019 GT A10 PP1, 1987 Buick Grand National, 1985 Mustang
Sai Li website shows kit using GT500 pumps now.
Logan@Lethal
Tampa, FL
Logan
That's correct, he did just switch to the 2020 GT500 hat, which is the same as the 13/14 GT500 pumps, repurposed.
GT350 pumps are the same w/ an internal check valve. Ford loves to repurpose stuff. lol
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP, 2023 F150 Powerboost
I believe you can also order the Sai Li kit straight from them with DW400's in it.
Logan@Lethal
Tampa, FL
Logan
Correct, it's per request and not typically worth the upcharge. You're better off going with his triple kit or one of our kits.
FastCarFanBoy
2013 GB GT
I started running out of fuel at just over 700whp on E85. Drilled out the hat and added DW400’s and that cleaned up the fueling issues.
