Dealership Botched Oil Change
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I guess there are people out there that don't work on thier own stuff, even the simplest of things....
mepawn
Ohio
Joseph
Interesting.... never thought of this as an issue as ive always had a bmr front k-member in all my s550s. Completely free and direct access to the oil filter.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
So you didn't reinstall the bellypan?
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Man dealers just suck. I took my Mach 1 for the first and only oil change since it was free. The next time I went to change the oil the filter was very loose and leaking some. Imagine being that inept on the first oil change of a brand new car. I never take my cars to dealers/mechanics unless its warranty work for this same reason or if I am unable to do the work at home.
mepawn
Ohio
Joseph
No I did not, not much for it to bolt up to. Im thinking of getting a custom metal pan fabricated with quick release tabs welded onto my bmr subframe
Pittpa
Pittsburgh PA 'Burbs
2019 GT 6MT
My dealer did not look up the spec or pull the stick and left me 2 quarts down with a dry stick. I checked it in the parking lot and got 2 free quarts of oil.
sdskinner73
Indiana, United States
Shawn
2018 premium GT A10 3.55s
I want to relay my recent experience with an oil change. It was the Mach's first oil change. Took it to the dealer and they said 1 to 1.5 hours. I waited. Car ready. On the way home I smell burning oil in the car. Ok, that's kind of an issue. I think it just may be some spilled oil during the service. Get home and park the car in the garage. Few days later, I take it for a drive and the smell is there again. I pull over and open the hood stick my nose in there and no real oil smell. Can't see any oil either. I smell the front wheel wells, no smell. I smell under the car, no oil smell. I run it home. Pulling in to the garage I notice oil small patches on the concrete. I get under the car from the side and can see a few oil drips coming from the back end of the belly pan by the oil plug. But the plug and pan are clean. I grab a flash light and move to the front of the engine and shine down to the filter area - oil has pooled in the belly pan. Ok, maybe the filter is loose. 😠
At this point I got to get it back to the dealer to see what the hell is going on. I'm not happy to drive the car not knowing what the issue is, but I take it back.
Well, I tell them its leaking oil and tell them its pooling on the belly pan. And I said what ever is the issue you need to take the belly pan off and clean it all up.
So, in the end, the plug and filter were tight. They just spilled a ton of oil when they changed the oil - likely at the filter.
They admitted the horrible job and all is well now.
I (now) know the oil filter is in a rough spot on the front of the engine and accessible only through a small access hatch. Removing the filter can get dodgy and oil will run down on the engine. But, come on Ford dealership. Btw, I'm not going to mention them, we settled up and they made it ok.
I'll probably start changing the oil myself. But owners beware if you take it to a dealer or quick change oil place or mechanic, make sure you feel with them doing the work.
Yep, that's all for today... 🤨
Oil changes on these cars are pretty simple. If your local dealership can’t do that right, they shouldn’t be employed. Took them longer with all the tools at their disposal than it takes me on jackstands with a few tools.
Even easier if you install a ronin type plug as well.
Jccams
Michigan
Jeff
2019 GT Premium, PP1, Magneride, A10
I changed mine before storage, first time on new to me Mustang. It went very well and I was using jackstands, reused the OEM plug. I want to get my 10R80 trans fluid changed and really do not want to do it, but am scared to death of having a dealer do it.
SBR70.3
Edmond, OK
2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
ShadesOfBloo
SE Virginia
1980 Datsun 210 wagon, 1992 Nissan 240SX, 2008 Evo, 2020 Mustang GT
...I (now) know the oil filter is in a rough spot on the front of the engine and accessible only through a small access hatch. Removing the filter can get dodgy and oil will run down on the engine.
I'd expect this from Jiffy Lube, not the dealer.
I've mostly done my own oil changes (never took the wheels off) and haven't had this kind of spill.
It's easier than changing the oil in my Evo which is, in turn, easier than changing the oil on a WRX.
(Helping a friend with an oil change is a big part of why I never considered a Subaru.)
Regardless, changing the oil yourself is probably the right move. 👍
bKennedy
Chapel Hill, NC
Bob
2018 Mustang GT PP-1
Ford fixed this with the S650... there is no longer a train hole.. you just have to REMOVE THE WHOLE PAN WITH ALL THOSE CLIPS to change the oil
Some fix, remove the whole pan. When I bought my first Mustang, 2011 GT, I had to tell them it took 8 quarts as that was the first time a 5.0 took 8 quarts; they looked at me like I was crazy. When I took my new 2018 in for a free oil change they knew it took 8 quarts, problem was that now it takes 10 quarts. They put in 8 and when I got home I checked it and found it was low. I no longer take my car to a dealer for an oil change, you just can't trust them. Do it yourself even if you get free oi changes.
daSNAK3
Cary, IL
Jake
2021 GT
On what year WRX?.. My 2018 was the easiest ever, fumoto valve and having the filter right there when you pop the hood... it was great.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I had a forester XT, same thing. Super easy, do an oil change in 5min.
Ozcraig
Brisbane, Australia
Craig
2017 Magnetic GT Coupe
Local dealership did the exact opposite on my 2017 GT. Replaced the oil with 9.5litres, which is the correct quantity for a 2018 GT, not the 7.6litres that the 2017 requires. Absolute morons can't even identify which car they are working on, let alone perform the correct task.
Keeffa
australia
keith
ford mustang 2018 gt
I had the first service done at the Ford dealer and never went back.
