Ghostrealm
This is the part that was scraped . Just a question can these be removed and replaced ? What is the area i circled called. Just the frame? I circled in the first pic yellow and the second pic blue. ITs the part of the frame that slopes and bends up like a ski.. Is this detachable? Since the bare metal is showing abut 2 inches fromt from the scrape would it make sense to use a self etching primer just to seal it again as that will be exposed to salt etc I wouldnt want that little scrape causing rust. What material is this it made from Alluminum? What primer does Ford use at the factory. I will try to paint and replicate back to original?Thanks,
