Check your oil pressure sensor ASAP
shelbyman
Huntington Beach, Ca.
Sandy
2016 GT 350 Track Package White w/blue stripes
It’s on the upper portion of the filter housing and is covered in a cylindrical heat shield.
Do you have to remove the heat shield in order to inspect the fitting? Am I correct in assuming the best way to inspect is to remove the front drivers wheel and look in from there? :question:
Off subject...not caring one bit for this new forum format...:thumbsdown:
btown93
Earth
Knight Industries 2000
agreed on website. Sometimes makes the site seem unusable, slow, shifty, just one of those that frustrates you so you just close it
Minn19
Minnesota
Jason
19 ZL1 1LE, 19 F150, 19 SB S5
I swear Ford trucks are made by an entirely different company. Have a Raptor and it's by far the best overall vehicle I've owned or been around.
Agreed, I’ve got a 16 SuperCrew Lariat that I love and has been completely trouble free inside and out.
chedder
Seattle
Randy
2017 GT350, 2017 Raptor SC, 2016 custom crew cab
Had to replace mine after 8 track days and 6 months of ownership. Started leaking at the track. Used 3 quarts just getting to my dealer. The fixed, no problems. Love the car and beating up on Porsches and BMW'S
shelbyman
Sandy
Can you tell me exactly where the leak was coming from? Were the threads still intact and tight and it was leaking from the housing of the sender OR was it leaking due to loose threads? I can't imagine the threads coming loose with the sealant compound on it. Mine is completely dry around the threads.
User5.2
Audi RS3
My 2016 has 15K miles and started a slow leak a few weeks ago. It was so slow I did not notice it, but my wife did when she nearly fell on her ass in the garage! The dealer put in oil dye and confirmed the oil leaking from the oil pressure threads, and then sealed the threads with teflon tape.
cking
17GT350AG/BS-MGW/UPR/ABLIP
That is not what service bulletin recommends do a search and print it up, it will probably come loose again. Always check here before you let the average ford dealer touch your car
Tank
9/11 - Never Forget
Above the Notches
G0853
Ford TSB 17-2271.
Zitrosounds
Madison, AL
Harold
Google Ford TSB 17-2271.
It never surprises me how a little some Tech's bother. Instead of taking the time to do the research and fix the issue accordingly. It is hard to find a good tech that gives a damn.
Zitrosounds
Madison, AL
Harold
What size socket does the EOP sensor take? The parts list on the TSB shows a 27 mm. I didn’t see any specialized socket listed.
I did this my self but I cant remember. Thought I used an O2 (7/8=22mm socket). But if the TSB says 27mm that's probably it. It just needs to be deepwell. No specialty socket needed.
S550VIN54
Raleigh NC
Stephen
2021 FJG Mach 1 HP
It would be great to get some photos of the leak or where the EOP sensor is located?
