At idle, it's always been just under 50, when temp is at 200 or slightly over.At what RPM? 50 at idle when the engine is at 200 is perfectly normal. I highly doubt the same weight Amsoil will raise your pressure and there is no need to raise it.
A heavier weight oil would likely boost oil pressure but I would not recommend that. Not that it matters but my oil pressure sits at about 48 lbs when at temp and idle. It raises to 63-65 lbs once I'm over 2000 RPM. This is on both our Hellcats.At idle, it's always been just under 50, when temp is at 200 or slightly over.
I know pressure is plenty high, was just wondering if Amsoil is more stable with temperature that you can see it on the gauge.
Thanks!
