Are my nuts too tight?
Performance nut
TX
2018 Mustang GT A10
I've anyways torqued my lug nuts on the ground. Was told since my studs and stud nuts are coated, they need to be torqued in the air. I realize they use a lower torque than uncoated but torquing them with no load seems counterintuitive.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I snug them in the air and then roll the car a few feet on the ground after lowering to release most of the preload on the tires from the suspension movement when lowering. Then tighten on the ground to spec.
That seems to give consistent torques that last. No need to check again after driving or anything, they’re always fine.
Fwiw my front studs are coated so I’m also using a bit less torque too.
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
This sounds like it would have come from the type of person who looks at an engine bay, points at the alternator, and says "nice turbo."
Bikeman315
Myrtle Beach, SC
Ira
The coating is for reduced corrosion. Unless specifically told not to you should still torque to the manufacturers specification.
NightmareMoon
In my case, yes, I’m using the correct torque for my application.
Angrey
Coral Gables
2016 GT350
Never torque with a gun. You run the risk of overtorque which has all sorts of potential issues from warping of rotors to deformation of the threads to fatigue and failure of the studs. Always use an actual manual torque wrench. Doing that in the air is dangerous, even with rock solid jack stands, it's not worth the risk of the vehicle falling.
Snug them in the air and torque to spec while safely on the ground. ESPECIALLY if your vehicle is up on a jack of any kind.
The bigger issue is one of dry vs lubricated torquing and the manufacturer's recommendations are based off dry, free of debris and contamination conditions.
Other aftermarket manufacturers (like ARP) may have procedures and specs that call for wet torque.
gfcobra04
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
Tighten in air with Milwaukee then lower car partially to get enough friction so I can torque the lug nuts. Also I use assembly lub on the studs and on the end of the nuts.
Angrey
Coral Gables
2016 GT350
I would only torque with lube if the manufacturer calls for it. Otherwise you may be over doing it.
Genxer
2015 Mustang GT / Perf pack / DIB
If your nuts are too tight, wear looser jeans.
For real, I simply lower the car enough to catch the tire enough where it won't rotate, and then torque everything before going all the way down.
DougS550
Fishers, Indiana
Doug
Did you say you put Assembly Lube on your Lug Studs prior to torquing?
