2016 GT P1X HO KIT
Jay-rod427
Kansas
2016 GT C/S
Idk how they are for p1x but for p1sc 3.5 pulley is good for 10 psi and 3.4 is 12 psi. Thats from procharger.
You have to be careful with Prochargers "official" ratings. They are usually rated at like 6,800 rpm... When you get down to 3.4 and smaller belt slip risk goes WAY up on the 6 rib.
SheepDog
Colorado
Dax
Correction: max speed on the P1 series blowers is 62,000rpm
whatsup62
Jupiter
P1SC-1 here...when I had the HO set-up I ran the 3.4 and saw 12.5 -13.5. The 3.4 technically maxes out the P1 at 7500ish rpm with the HO. I switched over to the stage 2 and run the 3.85 pulley which puts me roughly the same as the 3.4 on the HO. Car made 775/590 on E85 with this. Im moving to the D1x this weekend. You said you are going to the F1A but didn't mention you were going to the stage 2.?. Hopefully you are... I cant imagine the F1A on a 6 rib setup...also I assume you do not have the HO IC? No way that will support the F1.
yote41
pa
16 gt
What is the power or boost limits on the ho intercooler?
SheepDog
Colorado
Dax
Procharger states 750+, so around that at least.
S550_LGND
S550_LGND
Fresno, CA
Imma Buy The Whole Kit New I Already Have The Stage 2 Intercooler & Red Race BOV I Wasn’t Planning On Using The HO Brackets Haha But Damn Thanks For The Info!!
Notagain
United States
yellow 2016 5.0 totaled white 2018 A10 now
What pulley can I run?
Answer. Datalog.
How much psi should it make on a lower than stock compression engine?
Answer. Datalog.
Datalog is always the answer here. Its not a cookie cutter setup with an engine with lower than stock compression.
Datalog.
Did I mention you should data log?
Then once you do let us know what timing is at and what knock sensors say then go from there.
Until then this threads a guessing game!
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
Any updates
Jackson1320
California
Jaxson
2015 mustang gt
It's low because of the low compression motor. If you're revving to 8k then your already at the blower's RPM limit. You will need a stage 2 setup to get any more out of it. HO is much more limited with pulley sizes.
stage 2 or h.i doesn't make a diff. max rpm is max rpm
Jackson1320
California
Jaxson
2015 mustang gt
your problem is belt slip i guarantee it. a 3.4 pulley 6rib you are for sure slipping. you need a overdrive balancer so you can run a larger pulley on the blower to stop the slip. you go to a 8rib and you will gain like 3psi
