What dif fluid is everyone using?
CarTramrod
Raymore, MO
Tyrel
2018 Ford Mustang GT PP1, 1988 Ford Mustang LX
Will be installing gforce axles in the next few weeks and figure i may as well change the diff fluid since I have 40k miles on the car. Car has stage 3 Ben calimers mt82, catless longtubes,weld beadlocks with mt et street r's, and I have a whipple stage 2 ordered.
Eyesac
Reno NV
Isaac
2020 Mustang GT PP
I use Mobil 1 75W90, no modifiers, never noticed any increase in noise from the stock fluid...
SheepDog
Colorado
Dax
Amsoil 75-110
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
I use the Valvoline 75W90 squeeze pouches. The modifier included seems perfect for the trak lok because it feels the same in operation as it did with the stock fluid.
GregO
Illinois
S550 GTPP
3.73 Torsen, correct ?
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
I also used the Valvoline synthetic AND the Ford modifier even though the Valvolaine says "with modifier " .
John S
Novi, Michigan
2022 Mach 1 HP
Why does the Torsen application use a friction modifier when there are no clutch plates to chatter/grab?
Eyesac
Reno NV
Isaac
2020 Mustang GT PP
I read somewhere that they can make noise without the modifier. I've put regular gear oil in multiple torsen diffs and never experienced more noise...
robvas
MI
2011 GT
https://torsen.com/tbr-lube-friction-modifier/
This begs the question of whether or not friction modifier is actually necessary in a Torsen. Like I said earlier, the modifier is beneficial in smoothing out the operations of friction devices. However, because our friction properties are different than that of a clutch plate differential, you might not see the same symptoms of stick-slip behavior that those would. As noted, clutch plate differentials have a distinct tendency to chatter without friction modifier in the oil, and that chattering can become very objectionable. So, the modifier is essentially a requirement.
In a helical gear diff, however, the stick-slip tends to show up as an audible noise, described by some as a “rusty screw” noise, or as a squeak or moan. You tend to hear it in very low-speed turns, when the steering is at or near full-lock. So, you might hear it while maneuvering in a parking lot, or turning the car around in your driveway. This noise is, as I said, just a characteristic of the friction properties, and is normal. But, if you hear it a lot and it annoys you, adding a few ounces of friction modifier to the axle lubricant will almost always eliminate it. So, the bottom line is it’s up to you.
cerbomark
TN
auto parts stores carry it. It s such a tiny amount (4oz).
barron64
Auburn, AL
2018 Mustang GT convertible PP1, 6sp, 2006 Toyota Tundra Dbl Cab 4x4, 2009 Acura MDX, 2007 Toyota FJ Cruiser
Mobile Delvac 1, 75w-90 fully synthetic heavy duty use. You can buy it in gallon size for a better price point. Gear oil price by the quart, has gotten ridiculous in the last few years.
GregO
Illinois
S550 GTPP
Motul comp gear 75W-140 in my Torsen with NO modifier added. Fluid swapped twice in 60,000 street miles. No mpg loss. No stupid noises either.
