The Big Fat Track Car Cooling Thread
higdominator
Central Oklahoma
2016 GT PPP
That would be a good option. I had to replace the entire housing because it was leaking at the block. I use MMR's Oil filter relocation/cooler kit.
http://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&cPath=26_27&products_id=518
I like the MMR Kit, especially the price compared to the Mishi kit. Would you happen to have pics of where you remote mounted the filter? I'd love to get it mounted vertically.
I haven't really looked into the area since I'm focusing on my brakes right now, do you just cap off the lower radiator hose fittings for the factory cooler? Am I right to assume a non-PP lower hose would simply delete this and clean things up?
DB83
Granny Shifter
Spain
2017 Mustang GT
DB83
Granny Shifter
Spain
2017 Mustang GT
Awesome.....thanks!
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
mnmike59
2 hours South of BIR
2016 Mustang GT PP
Sorry, just now saw your questions. I haven't had it installed yet. The Heads were sent out to be ported and I just got them back, so Its all going back together this weekend. I'll grab some pics when it's in.
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
Since this is the big fat cooling thread, thought I'd document my cooling story / success here:
Car is a 2015 5.0 with twin 6262 turbo's, so anyone who wants to run twin turbo's at HPDE type track days you can do it. What you get is a track car with enough power to run with a Viper ACR, C7ZO6, GT3. I think my car is faster than the new Camaro ZL1, they disappear into the rear view mirror pretty quickly.:cheers: , and I was on 2 year old shagged out Yokohama AD08R's. Some fresh sticky rubber is coming up:
COTA Lap times are 2:36.4 Boost was 7psi, fuel was 50/50 e85, cylinder coolant temps are 230's and 240's. Turbo kit is a twinturbomustang.com low mount kit, with the large option intercooler.
I know NA cars can run faster than 2:36 at COTA, and I've still got a lot left with fresh stickier rubber and solving a small part throttle tuning issue.
Oh yeah, when I crank the boost up to +10psi and head to the drag strip, I've got a Hellcat eater as well......goal was a fun multi purpose car, and it is:ford:
Cooling mods are:
Mishimoto radiator
Anderson heat extractor hood
Earls engine oil cooler EAR-46000ERL (removed factory cooler)
Distilled water and water wetter type additive
Opened grill a little help more air enter
DIY plastic radiator shroud to force air through, not around
Ensure radiator shroud sealed, all air pass through coolers
170 degree thermo, but this doesn't help much
On a +90 degree TX day, I will need to shift at 6,000rpm to keep CHT under 250 deg F, but when ambient temps are in the mid 80's and lower, its full tilt with 7,500 rpm shifts. All testing at COTA
F0J
Winnipeg, Manitoba, Canada
François
2015 Mustang GT
Cooling mods are:
Mishimoto radiator
:headbang:
Weight added? Estimated power gains? What's your torque around 3,500? How does the chassis take the extra power when you lay it down while turning?
Once I blow my first motor, I'm half interested doing something very similar to you.
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
:headbang:
I'm right at 3,800 lbs with driver, 3,600 lbs without me and half tank gas. The kit added about 80lbs, and then I've done a lot of shit to reduce weight, like seats, drive shaft, plenty other stuff.
Haven't dyno'd yet but turbo's start spooling around 3,000rpm, so 3,500 and above you need to be careful with getting on the gas, I've spun out being to greedy. So all the extra power can only be used straight-line, and if you have good throttle control, you can bleed it in carefully. I try to stay in 3rd and torque out of corners, 2nd is a no go.
  • Like
Reactions: F0J
Earlj
Ct
2016 mustang gt, 2008 Z06
Cooling mods are:
Mishimoto radiator
I would be interested in seeing the rest of your rear brake cooling if you would not mind sharing. I burned up my rear pads pretty quickly. I run G-Loc R18 front and R12 rear.
Your install of the turbo kit looks real nice!!
The temps I run in up in the Northeast are usually below 80 degrees so I don"t usually have heat problems.
Cheers!!
MaverickGT
DFW Area, Texas
2016 Ruby Red GT PP
[MENTION=15674]Plimmer[/MENTION], Nice pic on track. Car looks good. I like the Anderson hood, my favorite. Blends in well. Do you have a build page?
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Short pad life does seem to be a pretty common complaint about the XP12/R12 pads. More so than any of the other grades.
Norm
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
Bump, bump, bump it up
ddozier
STL
www.trackcarbuilds.com
2015 Mustang GT PP
OK, here is what I have been doing.
Just have the under car to plumb should have that done this weekend.
